[postgis-tickets] r15660 - Add in missing news items.
Regina Obe
lr at pcorp.us
Thu Sep 7 20:48:46 PDT 2017
Author: robe
Date: 2017-09-07 20:48:45 -0700 (Thu, 07 Sep 2017)
New Revision: 15660
trunk/NEWS
Modified: trunk/NEWS
--- trunk/NEWS 2017-09-07 18:58:03 UTC (rev 15659)
+++ trunk/NEWS 2017-09-08 03:48:45 UTC (rev 15660)
@@ -23,9 +23,11 @@
- #524, Covers support for Polygon-on-polygon, line on line,
point on line for geography (Danny Götte)
-* Enhancements *
+* Enhancements and Fixes*
- Support for PostgreSQL 10
+ - Preliminary support for PostgreSQL 11
+ - #3645, Avoid loading logically deleted records from shapefiles
- #3747, Add zip4 and address_alphanumeric as attributes
to norm_addy tiger_geocoder type.
- #3748, address_standardizer lookup tables update
@@ -34,6 +36,10 @@
(Wouter Geraedts)
- #3684, Update to EPSG register v9
(Even Rouault)
+ - #3830, fix initialization of incompatible type (>=9.6) address_standardizer
+ - #3662, make shp2pgsql work in debug mode by sendig debug to stderr
+ - #3405, memory leak in lwgeom_to_points
+ - #3832, support wide integer fields as int8 in shp2pgsql
* Breaking Changes *
- Dropped support for PostgreSQL 9.2.
@@ -42,6 +48,7 @@
which means most aggs have to be dropped / recreated.
If you have views that utilize PostGIS aggs,
you'll need to drop before upgrade and recreate after upgrade
+ - #3578, ST_NumInteriorRings(POLYGON EMPTY) now returns 0 instead of NULL
PostGIS 2.4.0beta1
2017/09/02
