[postgis-tickets] [PostGIS] #3246: lwcollection_extract return object possibly referencing portions of argument
trac at osgeo.org
Fri Sep 8 05:32:25 PDT 2017
argument
Reporter: strk | Owner: pramsey
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 2.4.0
Component: postgis | Version: 2.1.x
Resolution: | Keywords:
Comment (by pramsey):
Well yes, looking at the function, once you start having an eye for the
kinds of leaks that hang around the whole lwgeom_release() pattern, you
see some others, so I removed them since I was there. Like most of our
leaks, they are leaking into the pgsql bathtub, which is drained at the
end of the function call anyways :) It's not something users would ever
perceive.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3246#comment:10>
