[postgis-tickets] r15662 - #3837, --enable-debug to set PARANOIA level
Paul Ramsey
pramsey at cleverelephant.ca
Fri Sep 8 12:20:47 PDT 2017
Author: pramsey
Date: 2017-09-08 12:20:46 -0700 (Fri, 08 Sep 2017)
New Revision: 15662
trunk/configure.ac
trunk/liblwgeom/lwgeom.c
trunk/liblwgeom/lwgeom_api.c
trunk/liblwgeom/lwgeom_geos.c
trunk/liblwgeom/lwgeom_geos_split.c
trunk/liblwgeom/ptarray.c
trunk/libpgcommon/lwgeom_pg.c
trunk/postgis_config.h.in
This required some re-working of the protobuf sections,
for reasons that aren't clear. However, hopefully that
re-working will also fix things for others. Basically,
the pkg-config portions seemed to only work by accident
for the folks who wrote them initially, so they are
improved, and the use of --without is more strongly
enforced in the conditional blocks
Modified: trunk/configure.ac
--- trunk/configure.ac 2017-09-08 13:04:38 UTC (rev 15661)
+++ trunk/configure.ac 2017-09-08 19:20:46 UTC (rev 15662)
@@ -857,7 +857,7 @@
[AS_HELP_STRING([--without-json], [build without json-c support])],
[CHECK_JSON="$withval"], [])
-if test "$CHECK_JSON" != "no"; then dnl {
+if test "$CHECK_JSON" != "no"; then
AC_ARG_WITH([jsondir],
[AS_HELP_STRING([--with-jsondir=PATH], [specify the json-c installation directory])],
@@ -903,7 +903,7 @@
AC_SUBST([JSON_LDFLAGS])
AC_SUBST([HAVE_JSON])
-fi dnl }
+fi
dnl ===========================================================================
@@ -927,63 +927,77 @@
[AS_HELP_STRING([--without-protobuf], [build without protobuf-c support])],
[CHECK_PROTOBUF="$withval"], [])
-if test "$CHECK_PROTOBUF" != "no"; then dnl {
+dnl User didn't turn off protobuf support so...
+if test "$CHECK_PROTOBUF" != "no"; then
-AC_ARG_WITH([protobufdir],
- [AS_HELP_STRING([--with-protobufdir=PATH], [specify the protobuf-c installation directory])],
- [PROTOBUFDIR="$withval"], [PROTOBUFDIR=])
+ AC_ARG_WITH([protobufdir],
+ [AS_HELP_STRING([--with-protobufdir=PATH], [specify the protobuf-c installation directory])],
+ [PROTOBUFDIR="$withval"], [PROTOBUFDIR=])
-if test ! "x$PROTOBUFDIR" = "x"; then
- dnl Make sure that the directory exists
- if test "x$PROTOBUFDIR" = "xyes"; then
- AC_MSG_ERROR([you must specify a parameter to --with-protobufdir, e.g. --with-protobufdir=/path/to])
- else
- AC_MSG_RESULT([Using user-specified protobuf-c directory: $PROTOBUFDIR])
+ dnl User specified the directory to find protobuf in, check that and
+ dnl fail if it doesn't work
+ if test ! "x$PROTOBUFDIR" = "x"; then
+ dnl Make sure that the directory exists
+ if test "x$PROTOBUFDIR" = "xyes"; then
+ AC_MSG_ERROR([you must specify a parameter to --with-protobufdir, e.g. --with-protobufdir=/path/to])
+ else
+ AC_MSG_RESULT([Using user-specified protobuf-c directory: $PROTOBUFDIR])
- dnl Add the include directory to PROTOBUF_CPPFLAGS
- PROTOBUF_CPPFLAGS="-I$PROTOBUFDIR/include"
- PROTOBUF_LDFLAGS="-L$PROTOBUFDIR/lib"
- fi
-fi
+ dnl Add the include directory to PROTOBUF_CPPFLAGS
+ PROTOBUF_CPPFLAGS="-I$PROTOBUFDIR/include"
+ PROTOBUF_LDFLAGS="-L$PROTOBUFDIR/lib"
+ fi
+ dnl Check that we can find the protobuf/protobuf.h header file
+ CPPFLAGS_SAVE="$CPPFLAGS"
+ CPPFLAGS="$PROTOBUF_CPPFLAGS"
+ AC_CHECK_HEADER([protobuf-c/protobuf-c.h], [],
+ AC_MSG_ERROR([unable to find $PROTOBUFDIR/include/protobuf-c/protobuf-c.h])
+ CPPFLAGS="$CPPFLAGS_SAVE"
-dnl Check that we can find the protobuf/protobuf.h header file
-CPPFLAGS_SAVE="$CPPFLAGS"
-CPPFLAGS="$PROTOBUF_CPPFLAGS"
-AC_CHECK_HEADER([protobuf-c/protobuf-c.h], [HAVE_PROTOBUF=yes], [])
-CPPFLAGS="$CPPFLAGS_SAVE"
+ dnl Ensure we can link against libprotobuf-c
+ LIBS_SAVE="$LIBS"
+ LIBS="$PROTOBUF_LDFLAGS"
+ AC_CHECK_LIB([protobuf-c], [protobuf_c_message_check], [],
+ AC_MSG_ERROR([unable to link protobuf-c from $PROTOBUFDIR/lib])
+ HAVE_PROTOBUF=yes
+ PROTOBUF_LDFLAGS="-L$PROTOBUFDIR/lib -lprotobuf-c"
+ LIBS="$LIBS_SAVE"
-dnl Ensure we can link against libprotobuf-c
-LIBS_SAVE="$LIBS"
-LIBS="$PROTOBUF_LDFLAGS"
-AC_CHECK_LIB([protobuf-c], [protobuf_c_message_check], [HAVE_PROTOBUF=yes; PROTOBUF_LDFLAGS="${PROTOBUF_LDFLAGS} -lprotobuf-c"], [HAVE_PROTOBUF=no])
-LIBS="$LIBS_SAVE"
+ dnl No user-specified protobuf dir, try to find one using pkg-config
+ else
+ if test "$PKG_CONFIG" = "no"; then
+ AC_MSG_WARN([Cannot find pkg-config, disabling protobuf support.])
+ HAVE_PROTOBUF=no
+ else
+ dnl Ensure libprotobuf-c is of minimum required version
+ PKG_CHECK_MODULES([PROTOBUFC], [libprotobuf-c >= 1.1.0], [
+ HAVE_PROTOBUF=yes;
+ PROTOBUF_CPPFLAGS=$PROTOBUFC_CFLAGS;
+ PROTOBUF_LDFLAGS=$PROTOBUFC_LIBS
+ [HAVE_PROTOBUF=no])
+ fi
+ fi
-if test "$PKG_CONFIG" = "no"; then
- AC_MSG_WARN([Cannot find pkg-config, disabling protobuf support.])
- HAVE_PROTOBUF=no
-else
- dnl Ensure libprotobuf-c is of minimum required version
- PKG_CHECK_MODULES([PROTOBUFC], [libprotobuf-c >= 1.1.0], [HAVE_PROTOBUF=yes], [HAVE_PROTOBUF=no])
-fi
+ if test "$HAVE_PROTOBUF" = "yes"; then
+ AC_PATH_PROG(PROTOCC, protoc-c)
+ if test "x$PROTOCC" = "x"; then
+ AC_MSG_WARN([Protobuf compiler missing, disabling protobuf support.])
+ HAVE_PROTOBUF=no
+ else
+ AC_DEFINE([HAVE_LIBPROTOBUF], [1], [Define to 1 if libprotobuf-c is present])
+ fi
+ fi
-if test "$HAVE_PROTOBUF" = "yes"; then
- AC_PATH_PROG(PROTOCC, protoc-c)
- if test "x$PROTOCC" = "x"; then
- AC_MSG_WARN([Protobuf compiler missing, disabling protobuf support.])
- HAVE_PROTOBUF=no
- else
- AC_DEFINE([HAVE_LIBPROTOBUF], 1, [Define to 1 if libprotobuf-c is present])
- fi
+ AC_SUBST([PROTOBUF_CPPFLAGS])
+ AC_SUBST([PROTOBUF_LDFLAGS])
+ AC_SUBST([HAVE_PROTOBUF])
fi
-AC_SUBST([PROTOBUF_CPPFLAGS])
-AC_SUBST([PROTOBUF_LDFLAGS])
-AC_SUBST([HAVE_PROTOBUF])
-fi dnl }
dnl Detect GTK+2.0 for GUI
@@ -1019,25 +1033,21 @@
-dnl Allow the user to enable debugging with --enable-debug
+dnl Allow the developer to turn on expensive checks and debugging flags
+dnl with --enable-debug
dnl
-dnl Currently we default to debug level 4. See DEBUG for more information.
-dnl
-AC_ARG_ENABLE([debug], AC_HELP_STRING([--enable-debug], [Enable verbose debugging messages]),
- [POSTGIS_DEBUG_LEVEL=4], [POSTGIS_DEBUG_LEVEL=0])
+AC_ARG_ENABLE([debug], AC_HELP_STRING([--enable-debug], [Enable debugging code and flags]),
+ [ENABLE_DEBUG=1], [ENABLE_DEBUG=0])
-AC_DEFINE_UNQUOTED([POSTGIS_DEBUG_LEVEL], [$POSTGIS_DEBUG_LEVEL], [PostGIS library debug level (0=disabled)])
+if test $ENABLE_DEBUG -eq 1; then
+ AC_DEFINE_UNQUOTED([PARANOIA_LEVEL], [10], [Enable use of memory checks])
+ CFLAGS="$CFLAGS -g"
+else
+ AC_DEFINE_UNQUOTED([PARANOIA_LEVEL], [0], [Disable use of memory checks])
+fi
-dnl ===========================================================================
-dnl Allow the user to enable GEOS profiling with --enable-profile
-dnl
-AC_ARG_ENABLE([profile], AC_HELP_STRING([--enable-profile], [Enable GEOS profiling messages]),
- [POSTGIS_PROFILE=1], [POSTGIS_PROFILE=0])
-AC_DEFINE_UNQUOTED([POSTGIS_PROFILE], [$POSTGIS_PROFILE], [Enable GEOS profiling (0=disabled)])
dnl Define version macros
dnl
Modified: trunk/liblwgeom/lwgeom.c
--- trunk/liblwgeom/lwgeom.c 2017-09-08 13:04:38 UTC (rev 15661)
+++ trunk/liblwgeom/lwgeom.c 2017-09-08 19:20:46 UTC (rev 15662)
@@ -1516,11 +1516,6 @@
LWPOLY *poly;
int i;
-#if PARANOIA_LEVEL > 0
- assert(o1 < 4);
- assert(o2 < 4);
-#endif
if ( (!in) || lwgeom_is_empty(in) ) return;
/* TODO: check for lwgeom NOT having the specified dimension ? */
Modified: trunk/liblwgeom/lwgeom_api.c
--- trunk/liblwgeom/lwgeom_api.c 2017-09-08 13:04:38 UTC (rev 15661)
+++ trunk/liblwgeom/lwgeom_api.c 2017-09-08 19:20:46 UTC (rev 15662)
@@ -32,11 +32,6 @@
#include <assert.h>
#include "../postgis_svn_revision.h"
- * Lower this to reduce integrity checks
-#define PARANOIA_LEVEL 1
const char *
lwgeom_version()
Modified: trunk/liblwgeom/lwgeom_geos.c
--- trunk/liblwgeom/lwgeom_geos.c 2017-09-08 13:04:38 UTC (rev 15661)
+++ trunk/liblwgeom/lwgeom_geos.c 2017-09-08 19:20:46 UTC (rev 15662)
@@ -1247,7 +1247,7 @@
* We should now have a collection
- if ( GEOSGeometryTypeId(geos_result) != COLLECTIONTYPE )
+ if ( GEOSGeomTypeId(geos_result) != COLLECTIONTYPE )
GEOSGeom_destroy(geos_result);
lwerror("Unexpected return from GEOSpolygonize");
Modified: trunk/liblwgeom/lwgeom_geos_split.c
--- trunk/liblwgeom/lwgeom_geos_split.c 2017-09-08 13:04:38 UTC (rev 15661)
+++ trunk/liblwgeom/lwgeom_geos_split.c 2017-09-08 19:20:46 UTC (rev 15662)
@@ -419,7 +419,7 @@
- if ( GEOSGeometryTypeId(polygons) != COLLECTIONTYPE )
+ if ( GEOSGeomTypeId(polygons) != COLLECTIONTYPE )
GEOSGeom_destroy(g1);
GEOSGeom_destroy(g2);
Modified: trunk/liblwgeom/ptarray.c
--- trunk/liblwgeom/ptarray.c 2017-09-08 13:04:38 UTC (rev 15661)
+++ trunk/liblwgeom/ptarray.c 2017-09-08 19:20:46 UTC (rev 15662)
@@ -391,11 +391,6 @@
double d, *dp1, *dp2;
POINT4D p;
- assert(o1 < 4);
- assert(o2 < 4);
-#endif
dp1 = ((double*)&p)+(unsigned)o1;
dp2 = ((double*)&p)+(unsigned)o2;
for (i=0 ; i < pa->npoints ; i++)
Modified: trunk/libpgcommon/lwgeom_pg.c
--- trunk/libpgcommon/lwgeom_pg.c 2017-09-08 13:04:38 UTC (rev 15661)
+++ trunk/libpgcommon/lwgeom_pg.c 2017-09-08 19:20:46 UTC (rev 15662)
@@ -29,8 +29,6 @@
#include <stdlib.h>
#include <stdarg.h>
#define PGC_ERRMSG_MAXLEN 256
Modified: trunk/postgis_config.h.in
--- trunk/postgis_config.h.in 2017-09-08 13:04:38 UTC (rev 15661)
+++ trunk/postgis_config.h.in 2017-09-08 19:20:46 UTC (rev 15662)
@@ -3,6 +3,13 @@
#include "postgis_svn_revision.h"
+/* Manually manipulate the POSTGIS_DEBUG_LEVEL, it is not affected by the
+ configure process */
+#define POSTGIS_DEBUG_LEVEL 0
+/* Define to 1 to enable memory checks in pointarray management. */
+#undef PARANOIA_LEVEL
/* Define to 1 if translation of program messages to the user's native
language is requested. */
#undef ENABLE_NLS
@@ -121,9 +128,6 @@
/* PostGIS build date */
#undef POSTGIS_BUILD_DATE
-/* PostGIS library debug level (0=disabled) */
-#undef POSTGIS_DEBUG_LEVEL
/* SFCGAL library version at buil time */
#undef POSTGIS_SFCGAL_VERSION
@@ -151,9 +155,6 @@
/* PostgreSQL server version */
#undef POSTGIS_PGSQL_VERSION
-/* Enable GEOS profiling (0=disabled) */
-#undef POSTGIS_PROFILE
/* PROJ library version */
#undef POSTGIS_PROJ_VERSION
