[postgis-tickets] r15668 - Remove PARANOIA blocks from lwgeom_api.c entirely
Paul Ramsey
pramsey at cleverelephant.ca
Fri Sep 8 14:34:35 PDT 2017
Author: pramsey
Date: 2017-09-08 14:34:35 -0700 (Fri, 08 Sep 2017)
New Revision: 15668
trunk/liblwgeom/lwgeom_api.c
Modified: trunk/liblwgeom/lwgeom_api.c
--- trunk/liblwgeom/lwgeom_api.c 2017-09-08 21:09:53 UTC (rev 15667)
+++ trunk/liblwgeom/lwgeom_api.c 2017-09-08 21:34:35 UTC (rev 15668)
@@ -245,7 +245,6 @@
uint8_t *ptr;
int zmflag;
-#if PARANOIA_LEVEL > 0
if ( ! pa )
lwerror("%s [%d] NULL POINTARRAY input", __FILE__, __LINE__);
@@ -254,10 +253,9 @@
if ( (n<0) || (n>=pa->npoints))
- lwerror("%s [%d] called with n=%d and npoints=%d", __FILE__, __LINE__, n, pa->npoints);
+ lwnotice("%s [%d] called with n=%d and npoints=%d", __FILE__, __LINE__, n, pa->npoints);
return 0;
-#endif
LWDEBUG(4, "getPoint4d_p called.");
@@ -338,7 +336,6 @@
uint8_t *ptr;
if ( ! pa )
@@ -347,10 +344,9 @@
return 0;
-#endif
LWDEBUGF(2, "getPoint3dz_p called on array of %d-dimensions / %u pts",
FLAGS_NDIMS(pa->flags), pa->npoints);
@@ -393,7 +389,6 @@
uint8_t *ptr;
int zmflag;
if ( ! pa )
@@ -402,10 +397,9 @@
return 0;
-#endif
LWDEBUGF(2, "getPoint3dm_p(%d) called on array of %d-dimensions / %u pts",
n, FLAGS_NDIMS(pa->flags), pa->npoints);
@@ -473,7 +467,6 @@
int
getPoint2d_p(const POINTARRAY *pa, int n, POINT2D *point)
if ( ! pa )
@@ -482,10 +475,9 @@
return 0;
-#endif
/* this does x,y */
memcpy(point, getPoint_internal(pa, n), sizeof(POINT2D));
