[postgis-tickets] [PostGIS] #3700: test_kmeans fails on winnie often on 32-bit and sometimes on 64-bit runs
trac at osgeo.org
Fri Sep 8 20:16:15 PDT 2017
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.5.0
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by robe):
hah guess it's still a problem. Just happened to me when testing r15671
on my mingw gcc 4.8.3 64-bit. though error is a little different so
perhaps not quite the same thing.
CUnit - A unit testing framework for C - Version 2.1-2
http://cunit.sourceforge.net/
Suite: computational_geometry
Test: test_lw_segment_side ...passed
Test: test_lw_segment_intersects ...passed
Test: test_lwline_crossing_short_lines ...passed
Test: test_lwline_crossing_long_lines ...passed
Test: test_lwline_crossing_bugs ...passed
Test: test_lwpoint_set_ordinate ...passed
Test: test_lwpoint_get_ordinate ...passed
Test: test_point_interpolate ...passed
Test: test_lwline_clip ...passed
Test: test_lwline_clip_big ...passed
Test: test_lwmline_clip ...passed
Test: test_geohash_point ...passed
Test: test_geohash_precision ...passed
Test: test_geohash ...passed
Test: test_geohash_point_as_int ...passed
Test: test_isclosed ...passed
Test: test_lwgeom_simplify ...passed
Test: test_lw_arc_center ...passed
Test: test_point_density ...passed
Test: test_kmeans ...Makefile:86: recipe for target 'check' failed
make[2]: *** [check] Segmentation fault
make[2]: Leaving directory
'/projects/postgis/branches/2.4/liblwgeom/cunit'
Makefile:205: recipe for target 'check' failed
make[1]: *** [check] Error 2
make[1]: Leaving directory '/projects/postgis/branches/2.4/liblwgeom'
GNUmakefile:16: recipe for target 'check' failed
make: *** [check] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3700#comment:11>
