[postgis-tickets] [PostGIS] #3835: ST_StraightSkeleton returns degenerate line segments
PostGIS trac at osgeo.org
Fri Sep 8 21:12:47 PDT 2017
  Reporter:  wrog     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS SFCGAL
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Changes (by robe):
 * milestone:  PostGIS 2.3.4 => PostGIS SFCGAL
Comment:
 Okay still seems to be an issue with head.
 Testing with:
 POSTGIS="2.4.0dev r15671" PGSQL="100" GEOS="3.7.0dev-CAPI-1.11.0 8fe2ce6"
 SFCGAL="1.3.1" PROJ="Rel. 4.9.1, 04 March 2015" GDAL="GDAL 2.2.1, released
 2017/06/23" LIBXML="2.7.8" LIBJSON="0.12" LIBPROTOBUF="1.2.1" RASTER
 WITH bt(box) AS (
   SELECT st_makebox2d(st_point(1296000,202400),st_point(1297000,212400))
 SELECT d.path[1], St_astext(d.geom) , ST_Length(d.geom)
 FROM bt, st_dump(
   st_straightskeleton(st_difference(st_buffer(box,2000,2),box))
 ) as d
 WHERE st_startpoint(d.geom) = st_endpoint(d.geom);
 I get output:
  path |                                   st_astext
 | st_length
    17 | LINESTRING(1295198.91236738 201598.91236738,1295198.91236738
 201598.91236738) |         0
    20 | LINESTRING(1295198.91236738 213201.08763262,1295198.91236738
 213201.08763262) |         0
    22 | LINESTRING(1297801.08763262 201598.91236738,1297801.08763262
    23 | LINESTRING(1297801.08763262 213201.08763262,1297801.08763262
 (4 rows)
 I've ticketed the issue upstream at
 https://github.com/Oslandia/SFCGAL/issues/143
 and will flag this as a SFCGAL since I don't think it needs fixing in
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3835#comment:2>
