[postgis-tickets] r15674 - change GEOS warning message to reflect the fact that while some functionality will be disabled for < 3.7.0. GEOS 3.7.0 probably won't be out before we release, so next best if one needs a stable tagged version is to use GEOS 3.6
Regina Obe
lr at pcorp.us
Sat Sep 9 18:52:23 PDT 2017
Author: robe
Date: 2017-09-09 18:52:23 -0700 (Sat, 09 Sep 2017)
New Revision: 15674
trunk/configure.ac
Modified: trunk/configure.ac
--- trunk/configure.ac 2017-09-09 08:54:15 UTC (rev 15673)
+++ trunk/configure.ac 2017-09-10 01:52:23 UTC (rev 15674)
@@ -857,7 +857,7 @@
[AS_HELP_STRING([--without-json], [build without json-c support])],
[CHECK_JSON="$withval"], [])
-if test "$CHECK_JSON" != "no"; then
+if test "$CHECK_JSON" != "no"; then
AC_ARG_WITH([jsondir],
[AS_HELP_STRING([--with-jsondir=PATH], [specify the json-c installation directory])],
@@ -903,7 +903,7 @@
AC_SUBST([JSON_LDFLAGS])
AC_SUBST([HAVE_JSON])
-fi
+fi
dnl ===========================================================================
@@ -928,7 +928,7 @@
[CHECK_PROTOBUF="$withval"], [])
dnl User didn't turn off protobuf support so...
-if test "$CHECK_PROTOBUF" != "no"; then
+if test "$CHECK_PROTOBUF" != "no"; then
AC_ARG_WITH([protobufdir],
[AS_HELP_STRING([--with-protobufdir=PATH], [specify the protobuf-c installation directory])],
@@ -947,11 +947,11 @@
PROTOBUF_CPPFLAGS="-I$PROTOBUFDIR/include"
PROTOBUF_LDFLAGS="-L$PROTOBUFDIR/lib"
fi
dnl Check that we can find the protobuf/protobuf.h header file
CPPFLAGS_SAVE="$CPPFLAGS"
CPPFLAGS="$PROTOBUF_CPPFLAGS"
- AC_CHECK_HEADER([protobuf-c/protobuf-c.h], [],
+ AC_CHECK_HEADER([protobuf-c/protobuf-c.h], [],
AC_MSG_ERROR([unable to find $PROTOBUFDIR/include/protobuf-c/protobuf-c.h])
CPPFLAGS="$CPPFLAGS_SAVE"
@@ -959,14 +959,14 @@
dnl Ensure we can link against libprotobuf-c
LIBS_SAVE="$LIBS"
LIBS="$PROTOBUF_LDFLAGS"
- AC_CHECK_LIB([protobuf-c], [protobuf_c_message_check], [],
+ AC_CHECK_LIB([protobuf-c], [protobuf_c_message_check], [],
AC_MSG_ERROR([unable to link protobuf-c from $PROTOBUFDIR/lib])
HAVE_PROTOBUF=yes
PROTOBUF_LDFLAGS="-L$PROTOBUFDIR/lib -lprotobuf-c"
LIBS="$LIBS_SAVE"
- dnl No user-specified protobuf dir, try to find one using pkg-config
+ dnl No user-specified protobuf dir, try to find one using pkg-config
else
if test "$PKG_CONFIG" = "no"; then
AC_MSG_WARN([Cannot find pkg-config, disabling protobuf support.])
@@ -974,10 +974,10 @@
else
dnl Ensure libprotobuf-c is of minimum required version
PKG_CHECK_MODULES([PROTOBUFC], [libprotobuf-c >= 1.1.0], [
- HAVE_PROTOBUF=yes;
+ HAVE_PROTOBUF=yes;
PROTOBUF_CPPFLAGS=$PROTOBUFC_CFLAGS;
PROTOBUF_LDFLAGS=$PROTOBUFC_LIBS
[HAVE_PROTOBUF=no])
fi
fi
@@ -1533,9 +1533,10 @@
AC_MSG_WARN([ --------- GEOS VERSION WARNING ------------ ])
AC_MSG_WARN([ You are building against GEOS ${GEOS_FULL_VERSION} ])
AC_MSG_WARN([ To take advantage of all the features of ])
-AC_MSG_WARN([ PostGIS we recommend you build using ])
-AC_MSG_WARN([ GEOS 3.7.0 or higher. You can download ])
-AC_MSG_WARN([ the latest versions from ])
+AC_MSG_WARN([ this PostGIS version requires GEOS 3.7.0 or higher which is not out yet.])
+AC_MSG_WARN([ To take advantage of most of the features of this PostGIS])
+AC_MSG_WARN([ we recommend GEOS 3.6 or higher])
+AC_MSG_WARN([ You can download the latest versions from ])
AC_MSG_WARN([ http://trac.osgeo.org/geos ])
AC_MSG_WARN()
fi
