[postgis-tickets] [PostGIS] #3839: shp2pgsql cunit tests failing on Windows
PostGIS trac at osgeo.org
Sat Sep 9 22:40:02 PDT 2017
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.3.4
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Comment (by robe):
 sadly this did not fix winnie's 32-bit issue.
 Suite: Shapefile Loader File shp2pgsql Test
   Test: test_ShpLoaderCreate() ...passed
   Test: test_ShpLoaderDestroy() ...make[2]: *** [Makefile:76: check]
 Segmentation fault
 make[2]: Leaving directory '/projects/postgis/branches/2.4/loader/cunit'
 make[1]: *** [Makefile:157: check] Error 2
 make[1]: Leaving directory '/projects/postgis/branches/2.4/loader'
 make: *** [GNUmakefile:16: check] Error 1
 e:\jenkins\postgis>exit 2
 Build step 'Execute Windows batch command' marked build as failure
 An attempt to send an e-mail to empty list of recipients, ignored.
 Triggering a new build of PG_ED_STOP
 Finished: FAILURE
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3839#comment:5>
