[postgis-tickets] [PostGIS] #3840: winnie 32-bit pg10 test failing on protobuf geobuf regress tests
trac at osgeo.org
Sun Sep 10 04:49:59 PDT 2017
Reporter: robe | Owner: Björn Harrtell
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by Björn Harrtell):
That said, the geobuf code is earlier and has seen less love than the mvt
code. Will, when I can, look into it more detailed. Could be similar type
size issues but in another place.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3840#comment:5>
