[postgis-tickets] [PostGIS] #3839: shp2pgsql cunit tests failing on Windows
PostGIS trac at osgeo.org
Mon Sep 11 08:02:38 PDT 2017
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.3.4
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Comment (by robe):
 just as a note of side history, these tests were originally turned off for
 no-gui as a result of this thread
 https://lists.osgeo.org/pipermail/postgis-devel/2010-December/011007.html
 On Thu, Dec 16, 2010 at 11:33:21AM +0000, Mark Cave-Ayland wrote:
 > strk wrote:
 > >Going on with my SUBDIR-based makefiles I stubled upon
 > >loader/cunit dir (running 'make check' under loader).
 > >W/out my change, those unit test don't run at all, is
 > >that expected ? Running the tests give lots of failures.
 > >So, are those tests meant to be run and should thus be fixed ?
 > >Or should they be just NOT run (and thus probably dropped) ?
 > Hmmm it looks like it was something Mark (Leslie) was working on, though
 > I get GTK reference errors so they would have absolutely no chance of
 > running unless ./configure was run with --with-gui.
 Alright then, as of r6414 'make check' under loader/  only runs the test
 when --with-gui was passed.
 When I'm finished with the top-level-dir pass this will be true also
 from the top-level dir...
 --strk;
 but given all the tests pass on the bots by enabling I think the comment
 is no longer valid.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3839#comment:12>
