[postgis-tickets] r15700 - #3844, new btree behavior for = and < >
Paul Ramsey
pramsey at cleverelephant.ca
Tue Sep 12 12:44:32 PDT 2017
Author: pramsey
Date: 2017-09-12 12:44:32 -0700 (Tue, 12 Sep 2017)
New Revision: 15700
trunk/liblwgeom/g_serialized.c
trunk/liblwgeom/liblwgeom.h.in
trunk/postgis/geography_btree.c
trunk/postgis/lwgeom_btree.c
trunk/regress/concave_hull.sql
trunk/regress/operators.sql
trunk/regress/operators_expected
trunk/topology/test/regress/topojson_expected
Modified: trunk/liblwgeom/g_serialized.c
--- trunk/liblwgeom/g_serialized.c 2017-09-12 16:04:46 UTC (rev 15699)
+++ trunk/liblwgeom/g_serialized.c 2017-09-12 19:44:32 UTC (rev 15700)
@@ -25,6 +25,7 @@
#include "liblwgeom_internal.h"
#include "lwgeom_log.h"
+#include "lwgeodetic.h"
* GSERIALIZED metadata utility functions.
@@ -66,6 +67,16 @@
return sizeof(GSERIALIZED) + 8 * sizeof(float) + sizeof(int);
+uint32_t gserialized_header_size(const GSERIALIZED *gser)
+ uint32_t sz = 8; /* varsize (4) + srid(3) + flags (1) */
+ if (gserialized_has_bbox(gser))
+ sz += gbox_serialized_size(gser->flags);
+ return sz;
uint32_t gserialized_get_type(const GSERIALIZED *s)
uint32_t *ptr;
@@ -169,6 +180,185 @@
return lwgeom_to_wkt(lwgeom_from_gserialized(g), WKT_ISO, 12, 0);
+/* Unfortunately including advanced instructions is something that
+only helps a small sliver of users who can build their own
+knowing the target system they will be running on. Packagers
+have to aim for the lowest common demoninator. So this is
+dead code for the forseeable future. */
+#define HAVE_PDEP 0
+#if HAVE_PDEP
+/* http://www.joshbarczak.com/blog/?p=454 */
+static uint64_t uint32_interleave_2(uint32_t u1, uint32_t u2)
+ uint64_t x = u1;
+ uint64_t y = u2;
+ uint64_t x_mask = 0x5555555555555555;
+ uint64_t y_mask = 0xAAAAAAAAAAAAAAAA;
+ return _pdep_u64(x, x_mask) | _pdep_u64(y, y_mask);
+static uint64_t uint32_interleave_3(uint32_t u1, uint32_t u2, uint32_t u3)
+ /* only look at the first 21 bits */
+ uint64_t x = u1 & 0x1FFFFF;
+ uint64_t y = u2 & 0x1FFFFF;
+ uint64_t z = u3 & 0x1FFFFF;
+ uint64_t x_mask = 0x9249249249249249;
+ uint64_t y_mask = 0x2492492492492492;
+ uint64_t z_mask = 0x4924924924924924;
+ return _pdep_u64(x, x_mask) | _pdep_u64(y, y_mask) | _pdep_u64(z, z_mask);
+#else
+ uint64_t x = u1;
+ uint64_t y = u2;
+ int i;
+ static uint64_t B[5] =
+ 0x5555555555555555,
+ 0x3333333333333333,
+ 0x0F0F0F0F0F0F0F0F,
+ 0x00FF00FF00FF00FF,
+ 0x0000FFFF0000FFFF
+ static uint64_t S[5] = { 1, 2, 4, 8, 16 };
+ for ( i = 4; i >= 0; i-- )
+ x = (x | (x << S[i])) & B[i];
+ y = (y | (y << S[i])) & B[i];
+ return x | (y << 1);
+#endif
+uint64_t gbox_get_sortable_hash(const GBOX *g)
+ uint32_t ux, uy;
+ float fx, fy;
+ * Since in theory the bitwise representation of an IEEE
+ * float is sortable (exponents come before mantissa, etc)
+ * we just copy the bits directly into an int and then
+ * interleave those ints.
+ if ( FLAGS_GET_GEODETIC(g->flags) )
+ GEOGRAPHIC_POINT gpt;
+ POINT3D p;
+ p.x = (g->xmax + g->xmin) / 2.0;
+ p.y = (g->ymax + g->ymin) / 2.0;
+ p.z = (g->zmax + g->zmin) / 2.0;
+ normalize(&p);
+ cart2geog(&p, &gpt);
+ fx = gpt.lon;
+ fy = gpt.lat;
+ memcpy(&ux, &fx, sizeof(uint32_t));
+ memcpy(&uy, &fy, sizeof(uint32_t));
+ else
+ fx = (g->xmax + g->xmin) / 2.0;
+ fy = (g->ymax + g->ymin) / 2.0;
+ return uint32_interleave_2(ux, uy);
+int gserialized_cmp(const GSERIALIZED *g1, const GSERIALIZED *g2)
+ int g1_is_empty, g2_is_empty, cmp;
+ GBOX box1, box2;
+ size_t sz1 = SIZE_GET(g1->size);
+ size_t sz2 = SIZE_GET(g2->size);
+ size_t hsz1 = gserialized_header_size(g1);
+ size_t hsz2 = gserialized_header_size(g2);
+ uint8_t *b1 = (uint8_t*)g1 + hsz1;
+ uint8_t *b2 = (uint8_t*)g2 + hsz2;
+ size_t bsz1 = sz1 - hsz1;
+ size_t bsz2 = sz2 - hsz2;
+ size_t bsz = bsz1 < bsz2 ? bsz1 : bsz2;
+ uint64_t hash1, hash2;
+ int32_t srid1 = gserialized_get_srid(g1);
+ int32_t srid2 = gserialized_get_srid(g2);
+ g1_is_empty = (gserialized_get_gbox_p(g1, &box1) == LW_FAILURE);
+ g2_is_empty = (gserialized_get_gbox_p(g2, &box2) == LW_FAILURE);
+ /* Empty == Empty */
+ if (g1_is_empty && g2_is_empty)
+ /* POINT EMPTY == POINT EMPTY */
+ /* POINT EMPTY < LINESTRING EMPTY */
+ uint32_t t1 = gserialized_get_type(g1);
+ uint32_t t2 = gserialized_get_type(g2);
+ return t1 == t2 ? 0 : (t1 < t2 ? -1 : 1);
+ /* Empty < Non-empty */
+ if (g1_is_empty)
+ return -1;
+ /* Non-empty > Empty */
+ if (g2_is_empty)
+ return 1;
+ /* Return equality for perfect equality only */
+ cmp = memcmp(b1, b2, bsz);
+ if ( bsz1 == bsz2 && srid1 == srid2 && cmp == 0 )
+ return 0;
+ /* using the centroids, and preferring the X axis */
+ hash1 = gbox_get_sortable_hash(&box1);
+ hash2 = gbox_get_sortable_hash(&box2);
+ if ( hash1 > hash2 )
+ return 1;
+ else if ( hash1 < hash2 )
+ return -1;
+ /* What, the hashes are equal? OK... sort on the */
+ /* box minima */
+ if (box1.xmin < box2.xmin)
+ return -1;
+ else if (box1.xmin > box2.xmin)
+ return 1;
+ if (box1.ymin < box2.ymin)
+ return -1;
+ else if (box1.ymin > box2.ymin)
+ return 1;
+ /* Still equal? OK... sort on the box maxima */
+ if (box1.xmax < box2.xmax)
+ return -1;
+ else if (box1.xmax > box2.xmax)
+ return 1;
+ if (box1.ymax < box2.ymax)
+ return -1;
+ else if (box1.ymax > box2.ymax)
+ return 1;
+ /* How about object size? Sort on that... */
+ if (hsz1 < hsz2)
+ return -1;
+ else if (hsz1 > hsz2)
+ return 1;
+ /* Well, they aren't memcmp equal, so we'll sort on the memcmp */
+ return cmp == 0 ? 0 : (cmp > 0 ? 1 : -1);
int gserialized_read_gbox_p(const GSERIALIZED *g, GBOX *gbox)
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in 2017-09-12 16:04:46 UTC (rev 15699)
+++ trunk/liblwgeom/liblwgeom.h.in 2017-09-12 19:44:32 UTC (rev 15700)
@@ -651,6 +651,12 @@
extern uint32_t gserialized_max_header_size(void);
+* Returns the size in bytes of the header, from the start of the
+* object up to the type number.
+extern uint32_t gserialized_header_size(const GSERIALIZED *gser);
* Extract the SRID from the serialized form (it is packed into
* three bytes so this is a handy function).
@@ -701,6 +707,16 @@
extern int gserialized_ndims(const GSERIALIZED *gser);
+* Return -1 if g1 is "less than" g2, 1 if g1 is "greater than"
+* g2 and 0 if g1 and g2 are the "same". Equality is evaluated
+* with a memcmp and size check. So it is possible that two
+* identical objects where one lacks a bounding box could be
+* evaluated as non-equal initially. Greater and less than
+* are evaluated by calculating a sortable key from the center
+* point of the object bounds.
+extern int gserialized_cmp(const GSERIALIZED *g1, const GSERIALIZED *g2);
* Call this function to drop BBOX and SRID
@@ -1942,6 +1958,12 @@
extern int gbox_is_valid(const GBOX *gbox);
+* Return a sortable key based on the center point of the
+* GBOX.
+extern uint64_t gbox_get_sortable_hash(const GBOX *g);
* Utility function to get type number from string. For example, a string 'POINTZ'
* would return type of 1 and z of 1 and m of 0. Valid
Modified: trunk/postgis/geography_btree.c
--- trunk/postgis/geography_btree.c 2017-09-12 16:04:46 UTC (rev 15699)
+++ trunk/postgis/geography_btree.c 2017-09-12 19:44:32 UTC (rev 15700)
@@ -54,78 +54,6 @@
p->z = GIDX_GET_MIN(gidx, 2) + GIDX_GET_MAX(gidx, 2);
-static int geography_cmp_internal(const GSERIALIZED *g1, const GSERIALIZED *g2)
- int cmp, have_box1, have_box2;
- int g1_is_empty = gserialized_is_empty(g1);
- int g2_is_empty = gserialized_is_empty(g2);
- size_t sz1 = SIZE_GET(g1->size);
- size_t sz2 = SIZE_GET(g2->size);
- size_t sz = sz1 < sz2 ? sz1 : sz2;
- /* Put aside some stack memory and use it for GIDX pointers. */
- char gboxmem1[GIDX_MAX_SIZE];
- char gboxmem2[GIDX_MAX_SIZE];
- GIDX *gbox1 = (GIDX*)gboxmem1;
- GIDX *gbox2 = (GIDX*)gboxmem2;
- POINT3D p1, p2;
- /* Empty == Empty */
- if (g1_is_empty && g2_is_empty)
- /* POINT EMPTY == POINT EMPTY */
- /* POINT EMPTY < LINESTRING EMPTY */
- uint32_t t1 = gserialized_get_type(g1);
- uint32_t t2 = gserialized_get_type(g2);
- return t1 == t2 ? 0 : (t1 < t2 ? -1 : 1);
- /* Empty < Non-empty */
- if (g1_is_empty)
- return -1;
- /* Non-empty > Empty */
- if (g2_is_empty)
- return 1;
- /* Return equality for perfect equality only */
- cmp = memcmp(g1, g2, sz);
- if ( sz1 == sz2 && cmp == 0 )
- return 0;
- /* Must be able to build box for each argument */
- /* (ie, not empty geometry) */
- have_box1 = gserialized_get_gidx_p(g1, gbox1);
- have_box2 = gserialized_get_gidx_p(g2, gbox2);
- if ( ! (have_box1 && have_box2) )
- lwerror("%s [%d] unable to calculate boxes of geographies", __FILE__, __LINE__);
- /* Order geographies more or less left-to-right */
- /* using the centroids, and preferring the X axis */
- geography_gidx_center(gbox1, &p1);
- geography_gidx_center(gbox2, &p2);
- if ( ! FP_EQUALS(p1.x, p2.x) )
- return p1.x < p2.x ? -1 : 1;
- if ( ! FP_EQUALS(p1.y, p2.y) )
- return p1.y < p2.y ? -1 : 1;
- if ( ! FP_EQUALS(p1.z, p2.z) )
- return p1.z < p2.z ? -1 : 1;
- /* Geographies that are the "same in centroid" */
- /* but didn't pass the exact equality test */
- /* First order smallest-first */
- if (sz1 != sz2)
- return sz1 < sz2 ? -1 : 1;
- /* Then just order on the memcmp return */
- else
- return cmp;
** BTree support function. Based on two geographies return true if
** they are "less than" and false otherwise.
@@ -135,7 +63,7 @@
GSERIALIZED *g1 = PG_GETARG_GSERIALIZED_P(0);
GSERIALIZED *g2 = PG_GETARG_GSERIALIZED_P(1);
- int cmp = geography_cmp_internal(g1, g2);
+ int cmp = gserialized_cmp(g1, g2);
if (cmp < 0)
PG_RETURN_BOOL(TRUE);
else
@@ -151,7 +79,7 @@
if (cmp <= 0)
else
@@ -167,7 +95,7 @@
if (cmp > 0)
else
@@ -183,7 +111,7 @@
if (cmp >= 0)
else
@@ -199,7 +127,7 @@
if (cmp == 0)
else
@@ -215,41 +143,5 @@
- PG_RETURN_INT32(geography_cmp_internal(g1, g2));
+ PG_RETURN_INT32(gserialized_cmp(g1, g2));
-#if 0
-** Calculate a hash code based on the geometry data alone
-static uint32 geography_hash(GSERIALIZED *g)
- return DatumGetUInt32(hash_any((void*)g, VARSIZE(g)));
-** BTree support function. Based on two geographies return true if
-** they are "equal" and false otherwise. This version uses a hash
-** function to try and shoot for a more exact equality test.
-PG_FUNCTION_INFO_V1(geography_eq);
-Datum geography_eq(PG_FUNCTION_ARGS)
- /* Perfect equals test based on hash */
- GSERIALIZED *g1 = PG_GETARG_GSERIALIZED_P(0);
- GSERIALIZED *g2 = PG_GETARG_GSERIALIZED_P(1);
- uint32 h1 = geography_hash(g1);
- uint32 h2 = geography_hash(g2);
- PG_FREE_IF_COPY(g1,0);
- PG_FREE_IF_COPY(g2,0);
- if ( h1 == h2 )
- PG_RETURN_BOOL(TRUE);
- PG_RETURN_BOOL(FALSE);
-#endif
Modified: trunk/postgis/lwgeom_btree.c
--- trunk/postgis/lwgeom_btree.c 2017-09-12 16:04:46 UTC (rev 15699)
+++ trunk/postgis/lwgeom_btree.c 2017-09-12 19:44:32 UTC (rev 15700)
@@ -49,354 +49,68 @@
PG_FUNCTION_INFO_V1(lwgeom_lt);
Datum lwgeom_lt(PG_FUNCTION_ARGS)
- GSERIALIZED *geom1 = PG_GETARG_GSERIALIZED_P(0);
- GSERIALIZED *geom2 = PG_GETARG_GSERIALIZED_P(1);
- GBOX box1;
- GBOX box2;
- bool empty1, empty2;
- POSTGIS_DEBUG(2, "lwgeom_lt called");
- error_if_srid_mismatch(gserialized_get_srid(geom1), gserialized_get_srid(geom2));
- POSTGIS_DEBUG(3, "lwgeom_lt passed getSRID test");
- empty1 = ( gserialized_get_gbox_p(geom1, &box1) == LW_FAILURE );
- empty2 = ( gserialized_get_gbox_p(geom2, &box2) == LW_FAILURE );
- PG_FREE_IF_COPY(geom1, 0);
- PG_FREE_IF_COPY(geom2, 1);
- POSTGIS_DEBUG(3, "lwgeom_lt getbox2d_p passed");
- if ( empty1 != empty2 )
- if ( ! FPeq(box1.xmin , box2.xmin) )
- if (box1.xmin < box2.xmin)
- if ( ! FPeq(box1.ymin , box2.ymin) )
- if (box1.ymin < box2.ymin)
- if ( ! FPeq(box1.xmax , box2.xmax) )
- if (box1.xmax < box2.xmax)
- if ( ! FPeq(box1.ymax , box2.ymax) )
- if (box1.ymax < box2.ymax)
+ GSERIALIZED *g1 = PG_GETARG_GSERIALIZED_P(0);
+ GSERIALIZED *g2 = PG_GETARG_GSERIALIZED_P(1);
+ if (cmp < 0)
+ PG_RETURN_BOOL(TRUE);
+ else
+ PG_RETURN_BOOL(FALSE);
PG_FUNCTION_INFO_V1(lwgeom_le);
Datum lwgeom_le(PG_FUNCTION_ARGS)
- GBOX box1;
- GBOX box2;
- POSTGIS_DEBUG(2, "lwgeom_le called");
+ if (cmp == 0)
+ else
PG_FUNCTION_INFO_V1(lwgeom_eq);
Datum lwgeom_eq(PG_FUNCTION_ARGS)
- GBOX box1;
- GBOX box2;
- bool result;
- POSTGIS_DEBUG(2, "lwgeom_eq called");
- gbox_init(&box1);
- gbox_init(&box2);
- result = FALSE;
- else if ( ! (FPeq(box1.xmin, box2.xmin) && FPeq(box1.ymin, box2.ymin) &&
- FPeq(box1.xmax, box2.xmax) && FPeq(box1.ymax, box2.ymax)) )
- result = FALSE;
+ if (cmp == 0)
else
- result = TRUE;
- PG_RETURN_BOOL(result);
PG_FUNCTION_INFO_V1(lwgeom_ge);
Datum lwgeom_ge(PG_FUNCTION_ARGS)
- GBOX box1;
- GBOX box2;
- POSTGIS_DEBUG(2, "lwgeom_ge called");
- if (box1.xmin > box2.xmin)
- if (box1.ymin > box2.ymin)
- if (box1.xmax > box2.xmax)
- if (box1.ymax > box2.ymax)
+ if (cmp >= 0)
+ else
PG_FUNCTION_INFO_V1(lwgeom_gt);
Datum lwgeom_gt(PG_FUNCTION_ARGS)
- GBOX box1;
- GBOX box2;
- POSTGIS_DEBUG(2, "lwgeom_gt called");
+ if (cmp > 0)
+ else
PG_FUNCTION_INFO_V1(lwgeom_cmp);
Datum lwgeom_cmp(PG_FUNCTION_ARGS)
- GBOX box1;
- GBOX box2;
- POSTGIS_DEBUG(2, "lwgeom_cmp called");
- if ( empty1 || empty2 )
- if ( empty1 && empty2 )
- PG_RETURN_INT32(1);
- else if ( empty1 )
- PG_RETURN_INT32(-1);
- else
- PG_RETURN_INT32(0);
Modified: trunk/regress/concave_hull.sql
--- trunk/regress/concave_hull.sql 2017-09-12 16:04:46 UTC (rev 15699)
+++ trunk/regress/concave_hull.sql 2017-09-12 19:44:32 UTC (rev 15700)
@@ -11,8 +11,8 @@
) As geom;
SELECT
- 'ST_ConcaveHull Lines 0.80', ST_Intersection(geom,ST_ConcaveHull(
- geom, 0.80) ) = geom As encloses_geom,
+ 'ST_ConcaveHull Lines 0.80', ST_Within(geom,ST_ConcaveHull(
+ geom, 0.80) ) As encloses_geom,
(ST_Area(ST_ConvexHull(geom))
- ST_Area(ST_ConcaveHull(geom, 0.80))) < (0.80 * ST_Area(ST_ConvexHull(geom) ) ) As reached_target
@@ -27,8 +27,8 @@
-- test holes vs. no holes - holes should still enclose but have smaller area than no holes --
SELECT
- 'ST_ConcaveHull Lines 0.80 holes', ST_Intersection(geom,ST_ConcaveHull(
- geom, 0.80, true) ) = geom As encloses_geom,
+ 'ST_ConcaveHull Lines 0.80 holes', ST_Within(geom,ST_ConcaveHull(
+ geom, 0.80, true) ) As encloses_geom,
ST_Area(ST_ConcaveHull(geom, 0.80, true)) < ST_Area(ST_ConcaveHull(geom, 0.80)) As reached_target
FROM ST_GeomFromText('MULTILINESTRING((106 164,30 112,74 70,82 112,130 94,
Modified: trunk/regress/operators.sql
--- trunk/regress/operators.sql 2017-09-12 16:04:46 UTC (rev 15699)
+++ trunk/regress/operators.sql 2017-09-12 19:44:32 UTC (rev 15700)
@@ -141,23 +141,26 @@
ORDER BY 1;
-- GROUP BY on empty
-SELECT '#3777', ST_AsText(geom), count(*) FROM (
-SELECT 'POINT(0 0)'::geometry geom UNION ALL
-SELECT 'POINT(0 0)'::geometry UNION ALL
-SELECT 'POINT(0 1)'::geometry UNION ALL
-SELECT 'LINESTRING(0 0,0 1)'::geometry UNION ALL
-SELECT 'GEOMETRYCOLLECTION EMPTY'::geometry UNION ALL
-SELECT 'POINT EMPTY'::geometry
-) foo
+SELECT '#3777', ST_AsText(geom), count(*)
+FROM (VALUES
+ ('POINT(0 0)'::geometry),
+ ('POINT(0 1)'::geometry),
+ ('LINESTRING(0 0,0 1)'::geometry),
+ ('GEOMETRYCOLLECTION EMPTY'::geometry),
+ ('POINT EMPTY'::geometry)
+) AS f(geom)
GROUP BY geom ORDER BY 2;
-SELECT '#3777.1', ST_AsText(geom), count(*) FROM (
-SELECT 'POINT EMPTY'::geometry UNION ALL
-SELECT 'GEOMETRYCOLLECTION EMPTY'::geometry geom
-) foo
+SELECT '#3777.1', ST_AsText(geom), count(*)
+FROM (VALUES
+ ('POINT EMPTY'::geometry),
+) AS f(geom)
Modified: trunk/regress/operators_expected
--- trunk/regress/operators_expected 2017-09-12 16:04:46 UTC (rev 15699)
+++ trunk/regress/operators_expected 2017-09-12 19:44:32 UTC (rev 15700)
@@ -42,7 +42,7 @@
ab2|f
ab3|t
eq1|t
-eq2|t
+eq2|f
eq3|f
cd1|4
bd1|0
@@ -56,11 +56,13 @@
ndov7|t
ndovm1|{1,2,3,4,5,8}
ndovm2|{1,2,4,6,7}
-#3777|GEOMETRYCOLLECTION EMPTY|2
+#3777|GEOMETRYCOLLECTION EMPTY|1
#3777|LINESTRING(0 0,0 1)|1
+#3777|POINT EMPTY|1
#3777|POINT(0 0)|3
#3777|POINT(0 1)|1
-#3777.1|GEOMETRYCOLLECTION EMPTY|2
+#3777.1|GEOMETRYCOLLECTION EMPTY|1
#3777.1|LINESTRING(0 0,0 1)|1
+#3777.1|POINT EMPTY|1
#3777.1|POINT(0 0)|3
#3777.1|POINT(0 1)|1
Modified: trunk/topology/test/regress/topojson_expected
--- trunk/topology/test/regress/topojson_expected 2017-09-12 16:04:46 UTC (rev 15699)
+++ trunk/topology/test/regress/topojson_expected 2017-09-12 19:44:32 UTC (rev 15700)
@@ -24,30 +24,30 @@
L1-vanilla|R4|{ "type": "MultiLineString", "arcs": [[3]]}
L2-vanilla|R1R2|{ "type": "MultiLineString", "arcs": [[9,-11],[4,-6]]}
L2-vanilla|R4|{ "type": "MultiLineString", "arcs": [[3]]}
-A1-vanilla|P1|{ "type": "MultiPolygon", "arcs": [[[20,5,-19,-20,-12,21]]]}
-A1-vanilla|P2|{ "type": "MultiPolygon", "arcs": [[[18,6,-17,-18,-13,19]]]}
-A1-vanilla|P3|{ "type": "MultiPolygon", "arcs": [[[16,7,-15,-16,-14,17]]]}
+A1-vanilla|P1|{ "type": "MultiPolygon", "arcs": [[[21,20,5,-19,-20,-12]]]}
+A1-vanilla|P2|{ "type": "MultiPolygon", "arcs": [[[19,18,6,-17,-18,-13]]]}
+A1-vanilla|P3|{ "type": "MultiPolygon", "arcs": [[[17,16,7,-15,-16,-14]]]}
A1-vanilla|P4|{ "type": "MultiPolygon", "arcs": [[[-2]]]}
-A1-vanilla|P5|{ "type": "MultiPolygon", "arcs": [[[-1],[25]]]}
-A2-vanilla|P1P2|{ "type": "MultiPolygon", "arcs": [[[20,5,6,-17,-18,-13,-12,21]]]}
-A2-vanilla|P3P4|{ "type": "MultiPolygon", "arcs": [[[-2]],[[16,7,-15,-16,-14,17]]]}
+A1-vanilla|P5|{ "type": "MultiPolygon", "arcs": [[[25],[-1]]]}
+A2-vanilla|P1P2|{ "type": "MultiPolygon", "arcs": [[[21,20,5,6,-17,-18,-13,-12]]]}
+A2-vanilla|P3P4|{ "type": "MultiPolygon", "arcs": [[[17,16,7,-15,-16,-14]],[[-2]]]}
L1-edgemap|R1|{ "type": "MultiLineString", "arcs": [[0,-2]]}
L1-edgemap|R2|{ "type": "MultiLineString", "arcs": [[2,-4]]}
L1-edgemap|R3|{ "type": "MultiLineString", "arcs": [[4]]}
L1-edgemap|R4|{ "type": "MultiLineString", "arcs": [[5]]}
L2-edgemap|R1R2|{ "type": "MultiLineString", "arcs": [[0,-2],[2,-4]]}
L2-edgemap|R4|{ "type": "MultiLineString", "arcs": [[4]]}
-A1-edgemap|P1|{ "type": "MultiPolygon", "arcs": [[[5,4,-4,-3,-2,0]]]}
-A1-edgemap|P2|{ "type": "MultiPolygon", "arcs": [[[3,9,-9,-8,-7,2]]]}
-A1-edgemap|P3|{ "type": "MultiPolygon", "arcs": [[[8,13,-13,-12,-11,7]]]}
+A1-edgemap|P1|{ "type": "MultiPolygon", "arcs": [[[5,4,3,-3,-2,-1]]]}
+A1-edgemap|P2|{ "type": "MultiPolygon", "arcs": [[[1,2,9,-9,-8,-7]]]}
+A1-edgemap|P3|{ "type": "MultiPolygon", "arcs": [[[7,8,13,-13,-12,-11]]]}
A1-edgemap|P4|{ "type": "MultiPolygon", "arcs": [[[-15]]]}
-A1-edgemap|P5|{ "type": "MultiPolygon", "arcs": [[[-16],[16]]]}
-A2-edgemap|P1P2|{ "type": "MultiPolygon", "arcs": [[[7,6,5,-5,-4,-3,-2,0]]]}
-A2-edgemap|P3P4|{ "type": "MultiPolygon", "arcs": [[[-9]],[[4,12,-12,-11,-10,3]]]}
+A1-edgemap|P5|{ "type": "MultiPolygon", "arcs": [[[15],[-17]]]}
+A2-edgemap|P1P2|{ "type": "MultiPolygon", "arcs": [[[7,6,5,4,-4,-3,-2,-1]]]}
+A2-edgemap|P3P4|{ "type": "MultiPolygon", "arcs": [[[2,3,11,-11,-10,-9]],[[-13]]]}
E32
E33
E34
E35
-A3-vanilla|P6|{ "type": "MultiPolygon", "arcs": [[[-33],[30,25],[1]],[[-34],[34]]]}
+A3-vanilla|P6|{ "type": "MultiPolygon", "arcs": [[[30,25],[-33],[1]],[[34],[-34]]]}
P1-vanilla|S2|{"type":"MultiPoint","coordinates":[[35,14]]}
Topology 'city_data' dropped
