[postgis-tickets] r15703 - Incorporate news cleanup and amendments from Darafei Praliaskouski
Regina Obe
lr at pcorp.us
Tue Sep 12 16:13:31 PDT 2017
Author: robe
Date: 2017-09-12 16:13:31 -0700 (Tue, 12 Sep 2017)
New Revision: 15703
trunk/NEWS
trunk/doc/release_notes.xml
Closes https://github.com/postgis/postgis/pull/140
Modified: trunk/NEWS
--- trunk/NEWS 2017-09-12 20:26:43 UTC (rev 15702)
+++ trunk/NEWS 2017-09-12 23:13:31 UTC (rev 15703)
@@ -13,14 +13,14 @@
- #3599, Geobuf output support via ST_AsGeobuf (Björn Harrtell)
- #3661, Mapbox vector tile output support via ST_AsMVT (Björn Harrtell / CartoDB)
- #3689, Add orientation checking and forcing functions (Dan Baston)
- - #3753, Gist penalty speed improvements for 2d and nd points
- (Darafei Praliaskouski)
+ - #3753, Gist penalty speed improvements for 2D and ND points
+ (Darafei Praliaskouski, Andrey Borodin)
- #3677, ST_FrechetDistance (Shinichi Sugiyama)
- Most aggregates (raster and geometry),
and all stable / immutable (raster and geometry) marked as parallel safe
- #2249, ST_MakeEmptyCoverage for raster (David Zwarg, ainomieli)
- #3709, Allow signed distance for ST_Project (Darafei Praliaskouski)
- - #524, Covers support for Polygon-on-polygon, line on line,
+ - #524, Covers support for polygon on polygon, line on line,
point on line for geography (Danny Götte)
* Enhancements and Fixes*
@@ -39,13 +39,14 @@
(Wouter Geraedts)
- #3684, Update to EPSG register v9
(Even Rouault)
- - #3830, fix initialization of incompatible type (>=9.6) address_standardizer
- - #3662, make shp2pgsql work in debug mode by sendig debug to stderr
- - #3405, memory leak in lwgeom_to_points
- - #3832, support wide integer fields as int8 in shp2pgsql
- - #3841, deterministic sorting support for empty geometries in btree geography
- - #3844, make = operator a strict equality test, and < > to rough "spatial sorting"
+ - #3830, Fix initialization of incompatible type (>=9.6) address_standardizer
+ - #3662, Make shp2pgsql work in debug mode by sendig debug to stderr
+ - #3405, Fixed memory leak in lwgeom_to_points
+ - #3832, Support wide integer fields as int8 in shp2pgsql
+ - #3841, Deterministic sorting support for empty geometries in btree geography
+ - #3844, Make = operator a strict equality test, and < > to rough "spatial sorting"
* Breaking Changes *
- Dropped support for PostgreSQL 9.2.
- #3810, GEOS 3.4.0 or above minimum required to compile
@@ -56,6 +57,12 @@
- #3578, ST_NumInteriorRings(POLYGON EMPTY) now returns 0 instead of NULL
- _ST_DumpPoints removed, was no longer needed after PostGIS 2.1.0
when ST_DumpPoints got reimplemented in C
+ - B-Tree index operators < = > changed to provide better spatial locality on sorting
+ and have expected behavior on GROUP BY.
+ If you have btree index for geometry or geography, you need to REINDEX it, or review
+ if it was created by accident and needs to be replaced with GiST index.
+ If your code relies on old left-to-right box compare ordering,
+ update it to use << >> operators
PostGIS 2.4.0beta1
2017/09/02
@@ -78,7 +85,7 @@
- #3738, raster: Using -s without -Y in raster2pgsql transforms
raster data instead of setting srid
- #3744, ST_Subdivide loses subparts of inverted geometries
- (Darafei Praliaskouski Komzpa)
+ (Darafei Praliaskouski)
- #3750, @ and ~ operator not always schema qualified in geometry
and raster functions. Causes restore issues.
(Shane StClair of Axiom Data Science)
Modified: trunk/doc/release_notes.xml
--- trunk/doc/release_notes.xml 2017-09-12 20:26:43 UTC (rev 15702)
+++ trunk/doc/release_notes.xml 2017-09-12 23:13:31 UTC (rev 15703)
@@ -6,9 +6,6 @@
<sect1>
<title>Release 2.4.0</title>
<para>Release date: 2017/09/xx</para>
- <para>This is a new feature release, with new functions, improved performance,
- all relevant bug fixes from PostGIS 2.3.4dev,and other goodies.</para>
<simplesect><title>New Features</title>
<para>#3822, Have postgis_full_version() also show and check version of
PostgreSQL the scripts were built against (Sandro Santilli)</para>
@@ -21,14 +18,14 @@
<para>#3599, Geobuf output support via ST_AsGeobuf (Björn Harrtell)</para>
<para>#3661, Mapbox vector tile output support via ST_AsMVT (Björn Harrtell / CartoDB)</para>
<para>#3689, Add orientation checking and forcing functions (Dan Baston)</para>
-<para>#3753, Gist penalty speed improvements for 2d and nd points
- (Darafei Praliaskouski)</para>
+<para>#3753, Gist penalty speed improvements for 2D and ND points
+ (Darafei Praliaskouski, Andrey Borodin)</para>
<para>#3677, ST_FrechetDistance (Shinichi Sugiyama)</para>
<para>Most aggregates (raster and geometry),
and all stable / immutable (raster and geometry) marked as parallel safe</para>
<para>#2249, ST_MakeEmptyCoverage for raster (David Zwarg, ainomieli)</para>
<para>#3709, Allow signed distance for ST_Project (Darafei Praliaskouski)</para>
-<para>#524, Covers support for Polygon-on-polygon, line on line,
+<para>#524, Covers support for polygon on polygon, line on line,
point on line for geography (Danny Götte)</para>
</simplesect>
@@ -36,6 +33,7 @@
<para>Many corrections to docs and several translations almost complete.
Andreas Schild who provided many corrections to core docs.
PostGIS Japanese translation team first to reach completion of translation.</para>
<para>Support for PostgreSQL 10</para>
<para>Preliminary support for PostgreSQL 11</para>
<para>#3645, Avoid loading logically deleted records from shapefiles</para>
@@ -47,11 +45,12 @@
(Wouter Geraedts)</para>
<para>#3684, Update to EPSG register v9
(Even Rouault)</para>
-<para>#3830, fix initialization of incompatible type (>=9.6) address_standardizer</para>
-<para>#3662, make shp2pgsql work in debug mode by sendig debug to stderr</para>
-<para>#3405, memory leak in lwgeom_to_points</para>
-<para>#3832, support wide integer fields as int8 in shp2pgsql</para>
-<para>#3841, deterministic sorting support for empty geometries in btree geography</para>
+<para>#3830, Fix initialization of incompatible type (>=9.6) address_standardizer</para>
+<para>#3662, Make shp2pgsql work in debug mode by sendig debug to stderr</para>
+<para>#3405, Fixed memory leak in lwgeom_to_points</para>
+<para>#3832, Support wide integer fields as int8 in shp2pgsql</para>
+<para>#3841, Deterministic sorting support for empty geometries in btree geography</para>
+<para>#3844, Make = operator a strict equality test, and < > to rough "spatial sorting"</para>
</simplesect>
<simplesect><title>Breaking Changes</title>
@@ -64,6 +63,12 @@
<para>#3578, ST_NumInteriorRings(POLYGON EMPTY) now returns 0 instead of NULL</para>
<para>_ST_DumpPoints removed, was no longer needed after PostGIS 2.1.0
when ST_DumpPoints got reimplemented in C</para>
+<para>B-Tree index operators < = > changed to provide better spatial locality on sorting
+ update it to use << >> operators.</para>
</simplesect>
</sect1>
<sect1>
