[postgis-tickets] [PostGIS] #3811: ./configure --help lists incorrect default install location
trac at osgeo.org
Wed Sep 13 05:44:03 PDT 2017
Reporter: chrismarx | Owner: pramsey
Type: task | Status: closed
Priority: low | Milestone: PostGIS 2.5.0
Component: postgis | Version: trunk
Resolution: wontfix | Keywords: documentation
Changes (by pramsey):
* status: new => closed
* resolution: => wontfix
Comment:
And, that help string is generated by autoconf, not us, while if you do
manually set the --prefix we do try and give you a huge warning
dnl
dnl Explain our prefix policy if necessary.
dnl
if test "$prefix" != "NONE"; then
AC_MSG_RESULT([------------------------------------------------------------------------])
AC_MSG_RESULT([ WARNING: You have set the --prefix to '$prefix'. But we
mostly ])
AC_MSG_RESULT([ ignore the --prefix. For your info, using the values
determined from ])
AC_MSG_RESULT([ $PG_CONFIG we will be installing: ])
AC_MSG_RESULT([ * postgis shared library in $PGSQL_LIBDIR ])
AC_MSG_RESULT([ * postgis SQL files in
$PGSQL_SHAREDIR/contrib/postgis-$POSTGIS_MAJOR_VERSION.$POSTGIS_MINOR_VERSION
AC_MSG_RESULT([ * postgis executables in $PGSQL_BINDIR ])
fi
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3811#comment:3>
