[postgis-tickets] r15713 - #2352, #3249, ST_RemoveIsoEdge is not documented
Paul Ramsey
pramsey at cleverelephant.ca
Wed Sep 13 13:20:00 PDT 2017
Author: pramsey
Date: 2017-09-13 13:20:00 -0700 (Wed, 13 Sep 2017)
New Revision: 15713
trunk/doc/extras_topology.xml
Modified: trunk/doc/extras_topology.xml
--- trunk/doc/extras_topology.xml 2017-09-13 20:03:07 UTC (rev 15712)
+++ trunk/doc/extras_topology.xml 2017-09-13 20:20:00 UTC (rev 15713)
@@ -1784,6 +1784,55 @@
</refentry>
</sect1>
+ <refentry id="ST_RemoveIsoEdge">
+ <refnamediv>
+ <refname>ST_RemoveIsoEdge</refname>
+ <refpurpose>Removes an isolated edge and returns description of action. If the edge is not isolated, then an exception is thrown.</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>text <function>ST_RemoveIsoEdge</function></funcdef>
+ <paramdef><type>varchar </type> <parameter>atopology</parameter></paramdef>
+ <paramdef><type>integer </type> <parameter>anedge</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>Removes an isolated edge and returns description of action. If the edge is not isolated, then an exception is thrown.</para>
+ <!-- use this format if new function -->
+ <para>Availability: 1.? </para>
+ <para>&sqlmm_compliant; SQL-MM: Topo-Geo and Topo-Net 3: Routine Details: X+1.3.3</para>
+ </refsection>
+ <refsection>
+ <title>Examples</title>
+ <programlisting>
+-- Remove an isolated node with no face --
+SELECT topology.ST_RemoveIsoNode('ma_topo', 7 ) As result;
+ result
+ Isolated node 7 removed
+</programlisting>
+ </refsection>
+ <!-- Optionally add a "See Also" section -->
+ <refsection>
+ <title>See Also</title>
+ <para><xref linkend="ST_AddIsoNode"/></para>
+ </refsection>
+ </refentry>
+ </sect1>
<sect1 id="Topology_Accessors">
<title>Topology Accessors</title>
<refentry id="GetEdgeByPoint">
