[postgis-tickets] r15721 - update docs to reflect = operator changed in 2.4.0. correct the examples to exhibit new behavior. Put a note in ~= which means what = used to mean
Regina Obe
lr at pcorp.us
Wed Sep 13 14:51:22 PDT 2017
Author: robe
Date: 2017-09-13 14:51:22 -0700 (Wed, 13 Sep 2017)
New Revision: 15721
trunk/doc/reference_operator.xml
References #3844 for PostGIS 2.4.0
Modified: trunk/doc/reference_operator.xml
--- trunk/doc/reference_operator.xml 2017-09-13 20:31:07 UTC (rev 15720)
+++ trunk/doc/reference_operator.xml 2017-09-13 21:51:22 UTC (rev 15721)
@@ -918,7 +918,8 @@
<refnamediv>
<refname>=</refname>
- <refpurpose>Returns <varname>TRUE</varname> if A's bounding box is the same as B's. Uses double precision bounding box.</refpurpose>
+ <refpurpose>Returns <varname>TRUE</varname> if the coordinates and coordinate order geometry/geography A
+ are the same as the coordinates and coordinate order of geometry/geography B.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -971,15 +972,18 @@
<para>Only geometry/geography that are exactly equal in all respects,
with the same coordinates, in the same order, are considered
equal by this operator. For "spatial equality", that ignores
- things like coordinate order, and can detect features that
- cover the same spatial area with different representations,
- use <xref linkend="ST_OrderingEquals" />
+ things like coordinate order, and can detect features that
+ cover the same spatial area with different representations,
+ use <xref linkend="ST_OrderingEquals" />
or <xref linkend="ST_Equals" /></para>
</note>
<caution><para>This operand will NOT make use of any indexes that may be available on the
geometries. For an index assisted exact equality test, combine = with &&.</para></caution>
+ <para>Changed: 2.4.0, in prior versions this was bounding box equality not a geometric equality. If you need bounding box equality, use <xref linkend="ST_Geometry_Same" /> instead.</para>
<para>&curve_support;</para>
<para>&P_support;</para>
@@ -991,7 +995,7 @@
<programlisting>SELECT 'LINESTRING(0 0, 0 1, 1 0)'::geometry = 'LINESTRING(1 1, 0 0)'::geometry;
?column?
- t
+ f
(1 row)
SELECT ST_AsText(column1)
@@ -1010,10 +1014,11 @@
('LINESTRING(0 0, 1 1)'::geometry),
('LINESTRING(1 1, 0 0)'::geometry)) AS foo
GROUP BY column1;
- st_astext
+ st_astext
LINESTRING(0 0,1 1)
-(1 row)
+ LINESTRING(1 1,0 0)
+(2 rows)
-- In versions prior to 2.0, this used to return true --
SELECT ST_GeomFromText('POINT(1707296.37 4820536.77)') =
@@ -1027,7 +1032,7 @@
<refsection>
<title>See Also</title>
- <para><xref linkend="ST_Equals" />, <xref linkend="ST_OrderingEquals" />
+ <para><xref linkend="ST_Equals" />, <xref linkend="ST_OrderingEquals" />, <xref linkend="ST_Geometry_Same" />
<!--, <xref linkend="ST_Geometry_LT" />, <xref linkend="ST_Geometry_GT" /> --></para>
</refsection>
</refentry>
@@ -1820,8 +1825,7 @@
which behavior your database has. To find out which behavior
your database has you can run the query below.
To check for true equality use <xref linkend="ST_OrderingEquals" /> or <xref
- linkend="ST_Equals" /> and to check for bounding box equality <xref linkend="ST_Geometry_EQ" />;
- operator is a safer option.</para>
+ linkend="ST_Equals" />.</para>
</warning>
</refsection>
@@ -1834,7 +1838,6 @@
t |
</programlisting>
- <para>The above can be used to test if you have the new or old behavior of ~= operator.</para>
</refsection>
<refsection>
