[postgis-tickets] r15728 - Only prepare statements on first run
Sandro Santilli
strk at kbt.io
Thu Sep 14 07:30:57 PDT 2017
Author: strk
Date: 2017-09-14 07:30:57 -0700 (Thu, 14 Sep 2017)
New Revision: 15728
trunk/topology/postgis_topology.c
Modified: trunk/topology/postgis_topology.c
--- trunk/topology/postgis_topology.c 2017-09-14 14:08:37 UTC (rev 15727)
+++ trunk/topology/postgis_topology.c 2017-09-14 14:30:57 UTC (rev 15728)
@@ -169,22 +169,24 @@
Oid argtypes[1];
static SPIPlanPtr plan = NULL;
- // prepare
- sql = "SELECT id,srid,precision,null::geometry"
- " FROM topology.topology "
- "WHERE name = $1::varchar";
argtypes[0] = CSTRINGOID;
- plan = SPI_prepare(sql, 1, argtypes);
- if ( ! plan )
+ if ( ! plan ) /* prepare on first call */
- cberror(be, "unexpected return (%d) from query preparation: %s",
- SPI_result, sql);
- return NULL;
+ sql = "SELECT id,srid,precision,null::geometry"
+ " FROM topology.topology "
+ "WHERE name = $1::varchar";
+ plan = SPI_prepare(sql, 1, argtypes);
+ if ( ! plan )
+ cberror(be, "unexpected return (%d) from query preparation: %s",
+ SPI_result, sql);
+ return NULL;
+ SPI_keepplan(plan);
+ /* SPI_freeplan to free, eventually */
- SPI_keepplan(plan);
- // SPI_freeplan to free, eventually
- // execute
+ /* execute */
values[0] = CStringGetDatum(name);
spi_result = SPI_execute_plan(plan, values, NULL, !be->data_changed, 1);
MemoryContextSwitchTo( oldcontext ); /* switch back */
@@ -194,7 +196,6 @@
if ( ! SPI_processed )
- //cberror(be, "no topology named '%s' was found", name);
if ( be->topoLoadFailMessageFlavor == 1 ) {
cberror(be, "No topology with name \"%s\" in topology.topology", name);
} else {
