[postgis-tickets] r15732 - Add check-no-trailing-blanks Makefile rule and run on `make check`
Daniel Baston
dbaston at gmail.com
Thu Sep 14 09:30:18 PDT 2017
Should this check .c, instead of .cpp ?
On Thu, Sep 14, 2017 at 11:57 AM, Sandro Santilli <strk at kbt.io> wrote:
> Author: strk
> Date: 2017-09-14 08:57:04 -0700 (Thu, 14 Sep 2017)
> New Revision: 15732
> Modified:
> trunk/GNUmakefile.in
> Log:
> Only checks .h and .c files, and skip those in .gitignore
> Modified: trunk/GNUmakefile.in
> --- trunk/GNUmakefile.in 2017-09-14 15:56:58 UTC (rev 15731)
> +++ trunk/GNUmakefile.in 2017-09-14 15:57:04 UTC (rev 15732)
> @@ -1,6 +1,6 @@
> -# Configuration directives are in postgis_config.h
> +# Configuration directives are in postgis_config.h
> @@ -35,8 +35,13 @@
> # TODO: drop 'test' target..
> test: check
> -check: all docs-check
> +check: all docs-check check-no-trailing-blanks
> +check-no-trailing-blanks:
> + ! find . -name '*.cpp' -o -name '*.h' | \
> + grep -vf .gitignore | \
> + xargs grep -Pn '[\t ]$$'
> installcheck:
> RUNTESTFLAGS="$(RUNTESTFLAGS) --extension" $(MAKE) check
> @@ -45,7 +50,7 @@
> distclean-local: clean-local
> rm -Rf autom4te.cache
> rm -f GNUmakefile
> - rm -f config.log config.cache config.status
> + rm -f config.log config.cache config.status
> rm -f postgis_config.h
> maintainer-clean-local: distclean-local
> @@ -53,7 +58,7 @@
> rm -f config.guess config.rpath config.sub
> rm -f libtool install-sh ltmain.sh
> -maintainer-clean:
> +maintainer-clean:
> @echo '------------------------------------------------------'
> @echo 'This command is intended for maintainers to use; it'
> @echo 'deletes files that may need special tools to rebuild.'
> @@ -85,7 +90,7 @@
> templategis-uninstall:
> $(MAKE) -C extras/template_gis uninstall
> -docs:
> +docs:
> $(MAKE) -C doc html
> docs-clean:
> @@ -96,7 +101,7 @@
> comments:
> $(MAKE) -C doc comments
> cheatsheets:
> $(MAKE) -C doc cheatsheets
> @@ -132,7 +137,7 @@
> astyle:
> ./astyle.sh
> commit:
> $(MAKE) astyle && $(MAKE) clean && $(MAKE) check && svn commit
> @@ -142,7 +147,7 @@
> svnrebase: authors.git
> git svn rebase --authors-file authors.git
> -postgis_svn_revision.h:
> +postgis_svn_revision.h:
> $(PERL) utils/svn_repo_revision.pl
> .PHONY: utils liblwgeom ChangeLog raster postgis_svn_revision.h
> postgis-tickets mailing list
> postgis-tickets at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-tickets
URL: <http://lists.osgeo.org/pipermail/postgis-tickets/attachments/20170914/e64ba008/attachment.html>
