[postgis-tickets] r15736 - numerous corrections from Andreas Schild on transifex
Regina Obe
lr at pcorp.us
Thu Sep 14 11:35:45 PDT 2017
Author: robe
Date: 2017-09-14 11:35:45 -0700 (Thu, 14 Sep 2017)
New Revision: 15736
trunk/doc/reference_raster.xml
Modified: trunk/doc/reference_raster.xml
--- trunk/doc/reference_raster.xml 2017-09-14 17:31:54 UTC (rev 15735)
+++ trunk/doc/reference_raster.xml 2017-09-14 18:35:45 UTC (rev 15736)
@@ -5695,7 +5695,7 @@
<programlisting>
WITH foo AS (
- SELECT ST_AddBand(ST_AddBand(ST_AddBand(ST_MakeEmptyRaster(3, 3, 0, 0, 1, -1, 0, 0, 0), 1, '8BUI', 1, 0), 2, '32BF', 3, -9999), 3, '16BSI', 0, 0) AS rast
+ SELECT ST_AddBand(ST_AddBand(ST_AddBand(ST_MakeEmptyRaster(3, 3, 0, 0, 1, -1, 0, 0, 0), 1, '8BUI'::text, 1, 0), 2, '32BF'::text, 3, -9999), 3, '16BSI', 0, 0) AS rast
SELECT
(ST_DumpValues(rast)).*
@@ -5711,7 +5711,7 @@
<programlisting>
WITH foo AS (
SELECT
(ST_DumpValues(rast, ARRAY[3, 1])).*
@@ -8101,7 +8101,7 @@
<refentry id="RT_ST_AsGDALRaster">
<refnamediv>
<refname>ST_AsGDALRaster</refname>
- <refpurpose>Return the raster tile in the designated GDAL Raster format. Raster formats are one of those supported by your compiled library. Use ST_GDALRasters() to get a list of formats supported by your library.</refpurpose>
+ <refpurpose>Return the raster tile in the designated GDAL Raster format. Raster formats are one of those supported by your compiled library. Use ST_GDALDrivers() to get a list of formats supported by your library.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -9407,7 +9407,7 @@
<term>distancex</term>
<listitem>
<para>
- The distance in pixels from the reference cell. So width of resulting matrix would be <code>2*distancex + 1</code>.If not specified only the reference cell is considered (neighborhood of 0).
+ The distance in pixels from the reference cell in x direction. So width of resulting matrix would be <code>2*distancex + 1</code>.If not specified only the reference cell is considered (neighborhood of 0).
</para>
</listitem>
</varlistentry>
@@ -9964,11 +9964,11 @@
<programlisting>
WITH foo AS (
- SELECT ST_AddBand(ST_MakeEmptyRaster(10, 10, 0, 0, 1, 1, 0, 0, 0), '32BF', 1, -1) AS rast
+ SELECT ST_AddBand(ST_MakeEmptyRaster(10, 10, 0, 0, 1, 1, 0, 0, 0), '32BF'::text, 1, -1) AS rast
SELECT
ST_MapAlgebra(rast, 1, NULL, 'ceil([rast]*[rast.x]/[rast.y]+[rast.val])')
-FROM foo
+FROM foo;
</programlisting>
</refsection>
@@ -9977,8 +9977,8 @@
<programlisting>
WITH foo AS (
- SELECT 1 AS rid, ST_AddBand(ST_AddBand(ST_AddBand(ST_MakeEmptyRaster(2, 2, 0, 0, 1, -1, 0, 0, 0), 1, '16BUI', 1, 0), 2, '8BUI', 10, 0), 3, '32BUI', 100, 0) AS rast UNION ALL
- SELECT 2 AS rid, ST_AddBand(ST_AddBand(ST_AddBand(ST_MakeEmptyRaster(2, 2, 0, 1, 1, -1, 0, 0, 0), 1, '16BUI', 2, 0), 2, '8BUI', 20, 0), 3, '32BUI', 300, 0) AS rast
+ SELECT 1 AS rid, ST_AddBand(ST_AddBand(ST_AddBand(ST_MakeEmptyRaster(2, 2, 0, 0, 1, -1, 0, 0, 0), 1, '16BUI', 1, 0), 2, '8BUI', 10, 0), 3, '32BUI'::text, 100, 0) AS rast UNION ALL
+ SELECT 2 AS rid, ST_AddBand(ST_AddBand(ST_AddBand(ST_MakeEmptyRaster(2, 2, 0, 1, 1, -1, 0, 0, 0), 1, '16BUI', 2, 0), 2, '8BUI', 20, 0), 3, '32BUI'::text, 300, 0) AS rast
SELECT
ST_MapAlgebra(
@@ -9989,7 +9989,7 @@
FROM foo t1
CROSS JOIN foo t2
WHERE t1.rid = 1
- AND t2.rid = 2
+ AND t2.rid = 2;
</programlisting>
</refsection>
@@ -10062,7 +10062,7 @@
<para>Create a new 1 band raster from our original that is a function of modulo 2 of the original raster band.</para>
<programlisting>
ALTER TABLE dummy_rast ADD COLUMN map_rast raster;
-UPDATE dummy_rast SET map_rast = ST_MapAlgebraExpr(rast,NULL,'mod([rast],2)') WHERE rid = 2;
+UPDATE dummy_rast SET map_rast = ST_MapAlgebraExpr(rast,NULL,'mod([rast]::numeric,2)') WHERE rid = 2;
SELECT
ST_Value(rast,1,i,j) As origval,
@@ -10088,7 +10088,7 @@
<para>Create a new 1 band raster of pixel-type 2BUI from our original that is reclassified and set the nodata value to be 0.</para>
<programlisting>ALTER TABLE dummy_rast ADD COLUMN map_rast2 raster;
- map_rast2 = ST_MapAlgebraExpr(rast,'2BUI','CASE WHEN [rast] BETWEEN 100 and 250 THEN 1 WHEN [rast] = 252 THEN 2 WHEN [rast] BETWEEN 253 and 254 THEN 3 ELSE 0 END', '0')
+ map_rast2 = ST_MapAlgebraExpr(rast,'2BUI'::text,'CASE WHEN [rast] BETWEEN 100 and 250 THEN 1 WHEN [rast] = 252 THEN 2 WHEN [rast] BETWEEN 253 and 254 THEN 3 ELSE 0 END'::text, '0')
WHERE rid = 2;
SELECT DISTINCT
@@ -10130,7 +10130,7 @@
<imagedata fileref="images/st_mapalgebraexpr01.png" />
</imageobject>
<caption>
- <para>original (column rast-view)</para>
+ <para>original (column rast_view)</para>
</caption>
</mediaobject>
</informalfigure>
@@ -10166,8 +10166,8 @@
ST_Band(rast_view,2)
- ST_Band(rast_view, 3) As rast_view_ma
+ ST_Band(rast_view, 3)
+ ) As rast_view_ma
FROM wind
WHERE rid=167;
</programlisting>
