[postgis-tickets] [PostGIS] #3731: SELECT * FROM testgeom WHERE ST_Intersects() and the back-end crashes
trac at osgeo.org
Thu Sep 14 16:00:48 PDT 2017
Reporter: zhuodao | Owner: pramsey
Type: defect | Status: closed
Priority: critical | Milestone: PostGIS 2.1.9
Component: postgis | Version: 2.2.x
Resolution: fixed | Keywords: ST_Intersects estimate_selectivity
| not a number
Changes (by pramsey):
* status: new => closed
* resolution: => fixed
Comment:
Thanks, your analysis of the problem was correct, the small data size and
relative uniformity led to a zero-ed out stats histogram and eventual
memory fault.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3731#comment:7>
