[postgis-tickets] r15746 - #3774, compute length of compound on arcs
Paul Ramsey
pramsey at cleverelephant.ca
Fri Sep 15 07:19:23 PDT 2017
Author: pramsey
Date: 2017-09-15 07:19:23 -0700 (Fri, 15 Sep 2017)
New Revision: 15746
trunk/liblwgeom/lwcompound.c
Modified: trunk/liblwgeom/lwcompound.c
--- trunk/liblwgeom/lwcompound.c 2017-09-15 05:36:10 UTC (rev 15745)
+++ trunk/liblwgeom/lwcompound.c 2017-09-15 14:19:23 UTC (rev 15746)
@@ -68,39 +68,35 @@
double lwcompound_length(const LWCOMPOUND *comp)
- double length = 0.0;
- LWLINE *line;
- if ( lwgeom_is_empty((LWGEOM*)comp) )
- return 0.0;
- line = lwcompound_stroke(comp, 32);
- length = lwline_length(line);
- lwline_free(line);
- return length;
+ return lwcompound_length_2d(comp);
double lwcompound_length_2d(const LWCOMPOUND *comp)
+ int i;
LWLINE *line;
return 0.0;
- length = lwline_length_2d(line);
+ for (i = 0; i < comp->ngeoms; i++)
+ length += lwgeom_length_2d(comp->geoms[i]);
return length;
int lwcompound_add_lwgeom(LWCOMPOUND *comp, LWGEOM *geom)
LWCOLLECTION *col = (LWCOLLECTION*)comp;
/* Empty things can't continuously join up with other things */
if ( lwgeom_is_empty(geom) )
LWDEBUG(4, "Got an empty component for a compound curve!");
return LW_FAILURE;
if( col->ngeoms > 0 )
POINT4D last, first;
@@ -111,15 +107,15 @@
getPoint4d_p(newline->points, 0, &first);
getPoint4d_p(prevline->points, prevline->points->npoints-1, &last);
if ( !(FP_EQUALS(first.x,last.x) && FP_EQUALS(first.y,last.y)) )
LWDEBUG(4, "Components don't join up end-to-end!");
- LWDEBUGF(4, "first pt (%g %g %g %g) last pt (%g %g %g %g)", first.x, first.y, first.z, first.m, last.x, last.y, last.z, last.m);
+ LWDEBUGF(4, "first pt (%g %g %g %g) last pt (%g %g %g %g)", first.x, first.y, first.z, first.m, last.x, last.y, last.z, last.m);
return LW_FAILURE;
col = lwcollection_add_lwgeom(col, geom);
return LW_SUCCESS;
@@ -181,7 +177,7 @@
if ( comp->ngeoms == 1 )
- return ptarrayarc_contains_point(lwcirc->points, pt);
+ return ptarrayarc_contains_point(lwcirc->points, pt);
else
@@ -200,10 +196,10 @@
/* Outside */
if (wn == 0)
return LW_OUTSIDE;
/* Inside */
return LW_INSIDE;
LWCOMPOUND *
lwcompound_construct_from_lwline(const LWLINE *lwline)
@@ -222,14 +218,14 @@
int npoints = 0;
if ( lwgeom_is_empty((LWGEOM*)lwcmp) )
return NULL;
npoints = lwgeom_count_vertices((LWGEOM*)lwcmp);
if ( where < 0 || where >= npoints )
lwerror("%s: index %d is not in range of number of vertices (%d) in input", __func__, where, npoints);
return NULL;
for ( i = 0; i < lwcmp->ngeoms; i++ )
LWGEOM* part = lwcmp->geoms[i];
@@ -244,7 +240,7 @@
- return NULL;
+ return NULL;
@@ -263,14 +259,14 @@
return NULL;
lwline = (LWLINE*)(lwcmp->geoms[lwcmp->ngeoms-1]);
if ( (!lwline) || (!lwline->points) || (lwline->points->npoints < 1) )
return NULL;
return lwline_get_lwpoint(lwline, lwline->points->npoints-1);
