[postgis-tickets] [PostGIS] #3774: st_length on compound curve is on linearized geometry
trac at osgeo.org
Fri Sep 15 21:43:54 PDT 2017
Reporter: strk | Owner: pramsey
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.1.9
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by robe):
you referenced the wrong commit. I assume you meant r15746.
You know it would be a lot faster if you just wrote:
References #3774 in your commit, then it would automatically show up
here.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3774#comment:2>
