[postgis-tickets] r15748 - typo corrections from Andreas Schild via transifex
Regina Obe lr at pcorp.us
Sat Sep 16 19:24:08 PDT 2017
Author: robe
Date: 2017-09-16 19:24:08 -0700 (Sat, 16 Sep 2017)
New Revision: 15748
   trunk/doc/po/templates/reference_raster.xml.pot
Modified: trunk/doc/po/templates/reference_raster.xml.pot
--- trunk/doc/po/templates/reference_raster.xml.pot	2017-09-17 01:40:38 UTC (rev 15747)
+++ trunk/doc/po/templates/reference_raster.xml.pot	2017-09-17 02:24:08 UTC (rev 15748)
@@ -6,7 +6,7 @@
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: http://bugs.kde.org\n"
-"POT-Creation-Date: 2017-09-14 18:44+0000\n"
+"POT-Creation-Date: 2017-09-17 01:52+0000\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -9967,7 +9967,7 @@
 "exporting. Note for this you'll need to have super user access to db since "
 "it uses server side lo functions. It will also export to path on server "
 "network. If you need export locally, use the psql equivalent lo_ functions "
-"which export to the local file system insteado fo the server file system."
+"which export to the local file system instead of the server file system."
 msgstr ""
 #. Tag: programlisting
