[postgis-tickets] r15753 - Add notes on optional protobuf-c dependency and some formatting fixes
bjorn at wololo.org
bjorn at wololo.org
Mon Sep 18 00:32:57 PDT 2017
Author: bjornharrtell
Date: 2017-09-18 00:32:57 -0700 (Mon, 18 Sep 2017)
New Revision: 15753
trunk/README.postgis
trunk/doc/installation.xml
Modified: trunk/README.postgis
--- trunk/README.postgis 2017-09-17 23:41:55 UTC (rev 15752)
+++ trunk/README.postgis 2017-09-18 07:32:57 UTC (rev 15753)
@@ -61,9 +61,9 @@
* GNU gettext
- The loader, and hence PostGIS, requires GNU gettext 0.14 or higher
- for translation support
- (typically in libc on GNU/Linux, in which case 0.17 is required).
+ The loader, and hence PostGIS, requires GNU gettext 0.14 or higher
+ for translation support
+ (typically in libc on GNU/Linux, in which case 0.17 is required).
* JSON-C (Optional, Version 0.9 or higher)
@@ -71,7 +71,7 @@
http://github.com/json-c/json-c/wiki
- You can get it installed in apt-based systems using::
+ You can get it installed in apt-based systems using:
apt-get install libjson0-dev
@@ -85,7 +85,18 @@
https://github.com/Oslandia/SFCGAL
+* protobuf-c (Optional, Version 1.1.0 or higher)
+ The protobuf-c library and compiler is required for ST_AsMVT and
+ ST_AsGeobuf output. Also, pkg-config is required to verify the correct
+ minimum version of protobuf-c.
+ https://github.com/protobuf-c/protobuf-c
+ To get packages on apt-based systems:
+ apt-get install libprotobuf-c-dev protobuf-c-compiler
CONFIGURATION
@@ -123,6 +134,9 @@
If you want to compile PostGIS *without* Topology support,
you must provide the ``--without-topology`` option.
+If you want to compile PostGIS *without* Protobuf formats support,
+you must provide the ``--without-protobuf`` option.
PostGIS will be compiled with sfcgal support if it is found.
You can explicitly state the location with --with-sfcgal=path/to/sfcgal
Modified: trunk/doc/installation.xml
--- trunk/doc/installation.xml 2017-09-17 23:41:55 UTC (rev 15752)
+++ trunk/doc/installation.xml 2017-09-18 07:32:57 UTC (rev 15753)
@@ -209,7 +209,7 @@
<listitem>
<para>
To enable ST_AsMVT protobuf-c library (for usage) and the protoc-c compiler (for building) are required.
- Also, pgk-config is required to verify the correct minimum version of protobuf-c.
+ Also, pkg-config is required to verify the correct minimum version of protobuf-c.
See <ulink url="https://github.com/protobuf-c/protobuf-c">protobuf-c</ulink>.
</para>
</listitem>
