[postgis-tickets] r15778 - Remove slicing logic from bounding box reader and
Paul Ramsey
pramsey at cleverelephant.ca
Wed Sep 20 08:46:14 PDT 2017
Author: pramsey
Date: 2017-09-20 08:46:14 -0700 (Wed, 20 Sep 2017)
New Revision: 15778
trunk/liblwgeom/g_serialized.c
trunk/postgis/gserialized_gist_2d.c
note why inline with the code so it can be done "right"
in a larger re-work of serialization (postgis 3) that
supports postgis-side compression. (Closes #3853)
Modified: trunk/liblwgeom/g_serialized.c
--- trunk/liblwgeom/g_serialized.c 2017-09-20 03:52:42 UTC (rev 15777)
+++ trunk/liblwgeom/g_serialized.c 2017-09-20 15:46:14 UTC (rev 15778)
@@ -85,7 +85,6 @@
uint32_t gserialized_get_type(const GSERIALIZED *s)
uint32_t *ptr;
- assert(s);
ptr = (uint32_t*)(s->data);
LWDEBUG(4,"entered");
if ( FLAGS_GET_BBOX(s->flags) )
Modified: trunk/postgis/gserialized_gist_2d.c
--- trunk/postgis/gserialized_gist_2d.c 2017-09-20 03:52:42 UTC (rev 15777)
+++ trunk/postgis/gserialized_gist_2d.c 2017-09-20 15:46:14 UTC (rev 15778)
@@ -589,22 +589,20 @@
GSERIALIZED *gpart;
uint8_t flags;
int result = LW_SUCCESS;
+ int gpart_is_slice = FALSE;
POSTGIS_DEBUG(4, "entered function");
- ** The most info we need is the 8 bytes of serialized header plus the
- ** of floats necessary to hold the bounding box.
+ ** Because geometry is declared as "storage = main" anything large
+ ** enough to take serious advantage of PG_DETOAST_DATUM_SLICE will have
+ ** already been compressed, which means the entire object will be
+ ** fetched and decompressed before a slice is taken, thus removing
+ ** any efficiencies gained from slicing. We need to move to
+ ** "storage = external" and implement our own geometry compressor
+ ** before we can take advantage of sliced retrieval.
- if (VARATT_IS_EXTENDED(gsdatum))
- gpart = (GSERIALIZED*)PG_DETOAST_DATUM_SLICE(gsdatum, 0, 8 + sizeof(BOX2DF));
- else
- gpart = (GSERIALIZED*)PG_DETOAST_DATUM(gsdatum);
+ gpart = (GSERIALIZED*)PG_DETOAST_DATUM(gsdatum);
flags = gpart->flags;
POSTGIS_DEBUGF(4, "got flags %d", gpart->flags);
@@ -621,28 +619,22 @@
/* No, we need to calculate it from the full object. */
GBOX gbox;
- GSERIALIZED *g = (GSERIALIZED*)PG_DETOAST_DATUM(gsdatum);
gbox_init(&gbox);
- if (gserialized_get_gbox_p(g, &gbox) == LW_FAILURE)
+ result = gserialized_get_gbox_p(gpart, &gbox);
+ if ( result == LW_SUCCESS )
- POSTGIS_DEBUG(4, "could not calculate bbox, returning failure");
- POSTGIS_FREE_IF_COPY_P(gpart, gsdatum);
- POSTGIS_FREE_IF_COPY_P(g, gsdatum);
- return LW_FAILURE;
+ result = box2df_from_gbox_p(&gbox, box2df);
- result = box2df_from_gbox_p(&gbox, box2df);
+ else
+ POSTGIS_DEBUG(4, "could not calculate bbox");
+ POSTGIS_DEBUGF(4, "result = %d, got box2df %s", result, result == LW_SUCCESS ? box2df_to_string(box2df) : "NONE");
- if ( result == LW_SUCCESS )
- POSTGIS_DEBUGF(4, "got box2df %s", box2df_to_string(box2df));
return result;
