[postgis-tickets] [PostGIS] #3853: datum slicing for bounding box retrieval is busted
trac at osgeo.org
Wed Sep 20 10:23:11 PDT 2017
Reporter: pramsey | Owner: pramsey
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Comment (by strk):
I was under the impression that you didn't get a double
detoasting even before, as the Datum pointer would always
be the same so second DETOAST attempt would be a no-op.
Just a cheap useless check (always false) in the worst
case and an opportunity for users to change storage type
(can be done on a table-by-table basis IIRC?) and then
benefit from the (now removed) code.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3853#comment:3>
