[postgis-tickets] [PostGIS] #3857: MVT returns for NULL "no data" which can be a problem for end use
trac at osgeo.org
Thu Sep 21 05:42:17 PDT 2017
Reporter: pramsey | Owner: Björn Harrtell
Type: enhancement | Status: assigned
Priority: high | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Keywords: |
A report from dmanzanares
I've been using concatenations of St_AsMVT to generate an MVT with
multiple layers in this way:
select
select st_asmvt(geom, 'layer1') FROM
(SELECT ST_AsMVTGeom(the_geom_webmercator, CDB_XYZ_Extent(16,11,5),
4096, 0, true) FROM
untitled_table where the_geom_webmercator &&
CDB_XYZ_Extent(16,11,5) ) as geom
select st_asmvt(geom, 'layer2') FROM
CDB_XYZ_Extent(16,11,5), 4096, 0, true) FROM
untitled_table_1 where the_geom_webmercator &&
This has 2 different, yet related, problems.
The first problem is that when St_AsMVT recieves 0 rows in geom, then it
returns NULL, when that happens, the concatenation operator operator
discards the bytearray of the other subquery, and sets the final result to
NULL. I would expect that it returns a zero-sized byte array instead of
NULL, to use the concatenation operator without wrappers/workarounds.
The second problem is that ST_AsMVTGeom returns NULL when the clipping
removes all the geometry from the tile. This causes this: "ERROR:
mvt_agg_transfn: geometry column cannot be null". I would expect that it
returns zero rows, or something that didn't trigger that error and that
ST_AsMVT could understand without wrappers/workarounds.
To make it easier to understand, this is a workaround that solves both
problems:
select
coalesce((
CDB_XYZ_Extent(16,11,5) ) as geom where geom is not null
coalesce((
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3857>
