[postgis-tickets] [PostGIS] #3857: MVT returns for NULL "no data" which can be a problem for end use
trac at osgeo.org
Thu Sep 21 12:07:33 PDT 2017
Reporter: pramsey | Owner: Björn Harrtell
Type: enhancement | Status: assigned
Priority: high | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by Björn Harrtell):
Discussed on IRC and we reached the following conclusions:
1. ST_AsMVTGeom should return NULL when appropriate and not throw up on
NULL input.
2. ST_AsMVT should ignore rows where geometry is NULL.
3. ST_AsMVT should return zero length bytea instead of NULL when
appropriate.
On an unrelated note @pramsey was also able to make my code crash the
backend with `select st_astext(ST_AsMVTGeom('POINT EMPTY'::geometry,
'BOX(0 0,2 2)'::box2d));`.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3857#comment:2>
