[postgis-tickets] r15791 - revise garden tests so can exercise anyelement now can generate tests for ST_AsMVT
Regina Obe
lr at pcorp.us
Thu Sep 21 23:34:36 PDT 2017
Author: robe
Date: 2017-09-21 23:34:36 -0700 (Thu, 21 Sep 2017)
New Revision: 15791
trunk/doc/xsl/postgis_gardentest.sql.xsl
Modified: trunk/doc/xsl/postgis_gardentest.sql.xsl
--- trunk/doc/xsl/postgis_gardentest.sql.xsl 2017-09-21 23:19:04 UTC (rev 15790)
+++ trunk/doc/xsl/postgis_gardentest.sql.xsl 2017-09-22 06:34:36 UTC (rev 15791)
@@ -26,6 +26,7 @@
<xsl:variable name='var_gj_version'>1</xsl:variable> <!-- GeoJSON version -->
<xsl:variable name='var_NDRXDR'>XDR</xsl:variable>
<xsl:variable name='var_text'>'monkey'</xsl:variable>
+ <xsl:variable name='var_row'>foo1</xsl:variable>
<xsl:variable name='var_buffer_style'>'quad_segs=1 endcap=square join=mitre mitre_limit=1.1'</xsl:variable>
<xsl:variable name='var_varchar'>'test'</xsl:variable>
<xsl:variable name='var_spheroid'>'SPHEROID["GRS_1980",6378137,298.257222101]'</xsl:variable>
@@ -490,7 +491,7 @@
<xsl:variable name='fndef'><xsl:value-of select="funcdef"/></xsl:variable>
<xsl:variable name='numparams'><xsl:value-of select="count(paramdef/parameter)" /></xsl:variable>
- <xsl:variable name='numparamgeoms'><xsl:value-of select="count(paramdef/type[contains(text(),'geometry') or contains(text(),'geography') or contains(text(),'box') or contains(text(), 'bytea')]) + count(paramdef/parameter[contains(text(),'WKT')]) + count(paramdef/parameter[contains(text(),'geomgml')]) + count(paramdef/parameter[contains(text(),'geomjson')]) + count(paramdef/parameter[contains(text(),'geomkml')])" /></xsl:variable>
+ <xsl:variable name='numparamgeoms'><xsl:value-of select="count(paramdef/type[contains(text(),'geometry') or contains(text(),'geography') or contains(text(),'box') or contains(text(), 'bytea') or contains(text(),'anyelement')] ) + count(paramdef/parameter[contains(text(),'WKT')]) + count(paramdef/parameter[contains(text(),'geomgml')]) + count(paramdef/parameter[contains(text(),'geomjson')]) + count(paramdef/parameter[contains(text(),'geomkml')])" /></xsl:variable>
<xsl:variable name='numparamgeogs'><xsl:value-of select="count(paramdef/type[contains(text(),'geography')] )" /></xsl:variable>
<xsl:variable name='log_label'><xsl:value-of select="funcdef/function" />(<xsl:value-of select="$fnargs" />)</xsl:variable>
@@ -627,6 +628,9 @@
<xsl:when test="contains(parameter, 'distance')">
<xsl:value-of select="$var_distance" />
</xsl:when>
+ <xsl:when test="contains(parameter, 'row')">
+ <xsl:value-of select="$var_row" />
+ </xsl:when>
<xsl:when test="contains(parameter, 'srid')">
<xsl:value-of select="$var_srid" />
</xsl:when>
