[postgis-tickets] r15800 - fixins for crash testing twkb, ST_GeomFromTWKB, and MVT functions.
Regina Obe
lr at pcorp.us
Fri Sep 22 14:04:38 PDT 2017
Author: robe
Date: 2017-09-22 14:04:38 -0700 (Fri, 22 Sep 2017)
New Revision: 15800
trunk/doc/reference_output.xml
trunk/doc/xsl/postgis_gardentest.sql.xsl
Add reference link to ST_GeomFromTWKB to ST_AsTWKB
Modified: trunk/doc/reference_output.xml
--- trunk/doc/reference_output.xml 2017-09-22 19:58:11 UTC (rev 15799)
+++ trunk/doc/reference_output.xml 2017-09-22 21:04:38 UTC (rev 15800)
@@ -1046,7 +1046,7 @@
<refsection>
<title>See Also</title>
- <para><xref linkend="ST_AsBinary" />, <xref linkend="ST_AsEWKB" />, <xref linkend="ST_AsEWKT" />, <xref linkend="ST_GeomFromText" /></para>
+ <para><xref linkend="ST_GeomFromTWKB" />, <xref linkend="ST_AsBinary" />, <xref linkend="ST_AsEWKB" />, <xref linkend="ST_AsEWKT" />, <xref linkend="ST_GeomFromText" /></para>
</refsection>
</refentry>
Modified: trunk/doc/xsl/postgis_gardentest.sql.xsl
--- trunk/doc/xsl/postgis_gardentest.sql.xsl 2017-09-22 19:58:11 UTC (rev 15799)
+++ trunk/doc/xsl/postgis_gardentest.sql.xsl 2017-09-22 21:04:38 UTC (rev 15800)
@@ -32,6 +32,7 @@
<xsl:variable name='var_spheroid'>'SPHEROID["GRS_1980",6378137,298.257222101]'</xsl:variable>
<xsl:variable name='var_matrix'>'FF1FF0102'</xsl:variable>
<xsl:variable name='var_boolean'>false</xsl:variable>
+ <xsl:variable name='var_geom_name'>the_geom</xsl:variable>
<xsl:variable name='var_logtable'>postgis_garden_log24</xsl:variable>
<xsl:variable name='var_logupdatesql'>UPDATE <xsl:value-of select="$var_logtable" /> SET log_end = clock_timestamp()
FROM (SELECT logid FROM <xsl:value-of select="$var_logtable" /> ORDER BY logid DESC limit 1) As foo
@@ -658,18 +659,33 @@
<xsl:when test="(contains(parameter,'geomjson'))">
<xsl:text>ST_AsGeoJSON(foo1.the_geom)</xsl:text>
</xsl:when>
+ <xsl:when test="contains(parameter, 'geom_name')">
+ '<xsl:value-of select="$var_geom_name" />'
+ </xsl:when>
+ <xsl:when test="contains(parameter, 'bounds')">
+ ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096))
+ </xsl:when>
<xsl:when test="(contains(type,'box') or type = 'geometry' or type = 'geometry ' or contains(type,'geometry set') or contains(type,'geometry winset') ) and (position() = 1 or count($func/paramdef/type[contains(text(),'geometry') or contains(text(),'box') or contains(text(), 'WKT') or contains(text(), 'bytea')]) = '1')">
<xsl:text>foo1.the_geom</xsl:text>
</xsl:when>
<xsl:when test="(type = 'geography' or type = 'geography ' or contains(type,'geography set')) and (position() = 1 or count($func/paramdef/type[contains(text(),'geography')]) = '1' )">
<xsl:text>geography(foo1.the_geom)</xsl:text>
</xsl:when>
<xsl:when test="contains(type,'box') or type = 'geometry' or type = 'geometry '">
<xsl:text>foo2.the_geom</xsl:text>
</xsl:when>
<xsl:when test="type = 'geography' or type = 'geography '">
<xsl:text>geography(foo2.the_geom)</xsl:text>
</xsl:when>
+ <xsl:when test="contains(type, 'bigint[]')">
+ <xsl:text>ARRAY[ST_XMin(foo1.the_geom)::bigint]</xsl:text>
+ </xsl:when>
<xsl:when test="contains(type, 'geometry[]') and count($func/paramdef/type[contains(text(),'geometry') or contains(text(),'box') or contains(text(), 'WKT') or contains(text(), 'bytea')]) = '1'">
ARRAY[foo1.the_geom]
</xsl:when>
@@ -685,9 +701,15 @@
<xsl:when test="contains(parameter, 'EWKB')">
<xsl:text>ST_AsEWKB(foo1.the_geom)</xsl:text>
</xsl:when>
+ <xsl:when test="contains(parameter, 'twkb')">
+ <xsl:text>ST_AsTWKB(foo1.the_geom)</xsl:text>
+ </xsl:when>
<xsl:when test="contains(type, 'bytea')">
<xsl:text>ST_AsBinary(foo1.the_geom)</xsl:text>
</xsl:when>
<xsl:when test="contains(parameter, 'Frac') or contains(parameter, 'frac') or contains(parameter, 'percent')">
<xsl:value-of select="$var_frac" />
</xsl:when>
@@ -700,7 +722,7 @@
<xsl:when test="contains(type, 'integer') and position() = 2">
<xsl:value-of select="$var_integer1" />
</xsl:when>
- <xsl:when test="contains(type, 'integer')">
+ <xsl:when test="contains(type, 'integer') or contains(type, 'int4')">
<xsl:value-of select="$var_integer2" />
</xsl:when>
<xsl:when test="contains(type, 'text')">
