[postgis-tickets] [PostGIS] #3840: winnie 32-bit pg10 test failing on protobuf geobuf regress tests
PostGIS trac at osgeo.org
Sat Sep 23 11:35:10 PDT 2017
  Reporter:  robe     |      Owner:  Björn Harrtell
      Type:  defect   |     Status:  assigned
  Priority:  high     |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by Björn Harrtell):
 In [changeset:"15802" 15802]:
 #!CommitTicketReference repository="" revision="15802"
 ST_AsGeobuf fix double comparison
 References #3840
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3840#comment:14>
