[postgis-tickets] [PostGIS] #3863: git builds always need upgrade
trac at osgeo.org
Sat Sep 23 11:35:35 PDT 2017
Reporter: komzpa | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
This might not be a global issue, might be something specific with how
komzpa is setup. Discussed on IRC with him.
Travis who also builds from github does show revision numbers. Though I
forget what magic strk put in place to make that happen.
PostgreSQL 9.6.5 on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu
4.8.4-2ubuntu1~14.04.3) 4.8.4, 64-bit
Postgis 2.4.0dev - r15801 - 2017-09-23 13:35:03
scripts 2.4.0dev r15801
raster scripts 2.4.0dev r15801
GEOS: 3.5.0-CAPI-1.9.0 r4084
PROJ: Rel. 4.8.0, 6 March 2012
GDAL: GDAL 2.1.0, released 2016/04/25
winnie also build from git (git.osgeo.org) and she shows revision numbers
as well.
I'm going to install the extension files from winnie to make sure it's not
happening during the generation of the extension files.
Komzpaa, are you absolutely sure your make install is working and
installing latest scripts.
As I mentioned on IRC, even if revision number wasn't coming thru, I
should still at least see a PGSQL=100 since
PostGIS 2.4.0beta. Yours is not showing that which makes me question if
they are the latest.
-- dialog from IRC below
07:38:23 Komzzpa: POSTGIS="2.4.0dev" GEOS="3.7.0dev-
CAPI-1.11.0 0" SFCGAL="1.3.1" PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL
2.1.2, released 2016/10/24" LIBXML="2.9.4" LIBJSON="0.12.1" (core procs
from "2.4.0dev" need upgrade) RASTER (raster procs from "2.4.0dev" need
upgrade) (sfcgal procs from "2.4.0dev" need upgrade)
07:38:54 Komzzpa: alter extension postgis update to
'2.4.0devnext'; alter extension postgis update to '2.4.0dev'; does not
help to get rid of "need upgrade"
07:39:06 Komzzpa: what could we have broken?
08:03:33 robe2: Komzzpa hmm that is odd where were you upgrading
from I thought it lists the r version though perhaps coming from git it
doesn't
08:04:35 robe2: Komzzpa mine lists the svn version -
POSTGIS="2.4.0dev r15800" PGSQL="100" GEOS="3.7.0dev-CAPI-1.11.0 316c4bc"
SFCGAL="1.3.1" PROJ="Rel. 4.9.1, 04 March 2015" GDAL="GDAL 2.2.1, released
2017/06/23" LIBXML="2.7.8" LIBJSON="0.12" LIBPROTOBUF="1.2.1" RASTER
08:04:57 robe2: it's very strange yours doesn't list PGSQL
08:05:54 robe2: you sure latest scripts got installed? perhaps the
binaries got installed but the scripts didn't that would trigger that
issue
08:06:33 Komzzpa: we've found that git builds make
postgis_scripts_released='2.4.0dev r0' and
postgis_scripts_installed='2.4.0'
08:07:27 Komzzpa: should I file a ticket?
08:07:46 robe2: Komzzpa hmm that's annoying. Yah that would be
good
08:08:06 robe2: I think we might be looking at revision numbers
though probably moving forward we'd have to stop that.
08:08:54 robe2: still even given that you should be seeing
PGSQL=... in your output if you are installing latest scripts
08:09:44 robe2: A bug I found in earlier is the PGSQL compare was
wrong so if you PGSQL you are using wasn't compiled with same gcc etc. as
what you are runnig, it gave a bogus need upgrade message
08:10:11 robe2: at very least it should list PGSQL ... which means
you don't have latest scripts installed.
08:10:17 Komzzpa: I think it's one of beta's
08:10:43 Komzzpa: I bumped into it exactly when tried to
figure out which one :)
08:11:11 * robe2 is going to miss revision numbers when we
move to git
08:11:17 robe2: increasing that is
08:11:39 Komzzpa: you can implement commit counting :)
08:11:56 robe2: Komzzpa oh how do you do that
08:12:42 Komzzpa: kom at junocat postgis % git log | grep
commit | wc -l
08:12:43 Komzzpa: 11803
08:12:49 Komzzpa: in a brainless way
08:13:11 Komzzpa: probably some sophisticated exists
08:14:12 Komzzpa: it won't be precisely comparable in
branches
08:17:16 robe2: Komzzpa though I have winnie building from
git.osgeo.org and she has r versions -
http://winnie.postgis.net:1500/job/PostGIS_EDB_Regress_winnie/5617/consoleFull
08:17:17 sigq: Title: PostGIS_EDB_Regress_winnie #5617 Console
[Jenkins] (at winnie.postgis.net:1500)
08:17:45 robe2: not sure how that's happening unless building from
github is different from git.osgeo.org (and strk has something cooked up
there)
08:18:47 Komzzpa:
#POSTGIS_SVN_REVISION=passed_in_by_buildbot
08:18:58 Komzzpa: this may be a builder's trick
08:21:32 robe2: Komzzpa hmm I think I had put that in a while ago
though I don't see it being used and where I'm passing it in anymore
08:23:08 robe2: Komzzpa travis has revision number too and he
builds from git - https://travis-ci.org/postgis/postgis?branch=svn-trunk
08:23:09 sigq: Title: Travis CI - Test and Deploy Your Code with
Confidence (at travis-ci.org)
08:24:58 Komzzpa: hmm
08:25:19 Komzzpa: may it be that it is chopped off somehow
on deb build...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3863#comment:1>
