[postgis-tickets] r15812 - Do not check upgrades as docker build does not have upgradable versions
Sandro Santilli
strk at kbt.io
Sun Sep 24 02:26:31 PDT 2017
Author: strk
Date: 2017-09-24 02:26:31 -0700 (Sun, 24 Sep 2017)
New Revision: 15812
Removed:
branches/2.1/utils/check_all_upgrades.sh
branches/2.1/.drone.yml
Modified: branches/2.1/.drone.yml
--- branches/2.1/.drone.yml 2017-09-24 09:18:15 UTC (rev 15811)
+++ branches/2.1/.drone.yml 2017-09-24 09:26:31 UTC (rev 15812)
@@ -21,5 +21,3 @@
- service postgresql start
- make check RUNTESTFLAGS=-v
- make install
- - utils/check_all_upgrades.sh \
- `grep '^POSTGIS_' Version.config | cut -d= -f2 | paste -sd '.'`
Deleted: branches/2.1/utils/check_all_upgrades.sh
--- branches/2.1/utils/check_all_upgrades.sh 2017-09-24 09:18:15 UTC (rev 15811)
+++ branches/2.1/utils/check_all_upgrades.sh 2017-09-24 09:26:31 UTC (rev 15812)
@@ -1,24 +0,0 @@
-#!/bin/sh
-if test -z "$1"; then
- echo "Usage: $0 <to_version>" >&2
- exit 1
-fi
-to_version="$1"
-BUILDDIR=$PWD
-EXTDIR=`pg_config --sharedir`/extension/
-cd $EXTDIR
-'ls' postgis--* | grep -v -- '--.*--' |
-sed 's/^postgis--\(.*\)\.sql/\1/' | while read fname; do
- from_version="$fname"
- UPGRADE_PATH="${from_version}--${to_version}"
- if test -e postgis--${UPGRADE_PATH}.sql; then
- echo "Testing upgrade $UPGRADE_PATH"
- export RUNTESTFLAGS="-v --extension --upgrade-path=${UPGRADE_PATH}"
- make -C ${BUILDDIR}/regress check || exit 1
- else
- echo "Missing script for $UPGRADE_PATH upgrade" >&2
- fi
-done
