[postgis-tickets] [PostGIS] #3866: Server crashing sometimes from large values in twkb encoding
PostGIS trac at osgeo.org
Mon Sep 25 13:57:13 PDT 2017
 Reporter:  nicklas  |      Owner:  nicklas
     Type:  defect   |     Status:  assigned
 Priority:  medium   |  Milestone:  PostGIS 2.3.4
Component:  postgis  |    Version:  2.3.x
 Keywords:           |
 The attached geometry writes beyond the buffer.
 In some cases it crashes the server.
 It is caused from a large value that encodes to a variable integer of 10
 bytes instead of the expected max 8 bytes. Most of the time this doesn't
 do any harm. But if the preceding point leaves exactly 8 bytes left in the
 buffer, the space check will not reallocate and writing 9 or 10 bytes will
 cause writing beyond the buffer.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3866>
