[postgis-tickets] [PostGIS] #3866: Server crashing sometimes from large values in twkb encoding
PostGIS trac at osgeo.org
Mon Sep 25 13:59:39 PDT 2017
  Reporter:  nicklas  |      Owner:  nicklas
      Type:  defect   |     Status:  assigned
  Priority:  medium   |  Milestone:  PostGIS 2.3.4
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Comment (by nicklas):
 increased the expected max size of variable integer to 16 bytes instead of
 8 bytes.
 That should always be enough since the value gets truncated by casting to
 int64_t before encoding to variable integer
 fixed in trunk r15817
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3866#comment:1>
