[postgis-tickets] r15844 - Drop trailing blank from vector_tile.proto
Sandro Santilli
strk at kbt.io
Tue Sep 26 22:46:49 PDT 2017
Author: strk
Date: 2017-09-26 22:46:49 -0700 (Tue, 26 Sep 2017)
New Revision: 15844
trunk/postgis/vector_tile.proto
Modified: trunk/postgis/vector_tile.proto
--- trunk/postgis/vector_tile.proto 2017-09-27 04:13:17 UTC (rev 15843)
+++ trunk/postgis/vector_tile.proto 2017-09-27 05:46:49 UTC (rev 15844)
@@ -41,7 +41,7 @@
optional GeomType type = 3 [ default = UNKNOWN ];
// Contains a stream of commands and parameters (vertices).
- // A detailed description on geometry encoding is located in
+ // A detailed description on geometry encoding is located in
// section 4.3 of the specification.
repeated uint32 geometry = 4 [ packed = true ];
