[postgis-tickets] r15848 - Make all suite names one-word, lowercase
Paul Ramsey
pramsey at cleverelephant.ca
Wed Sep 27 13:54:59 PDT 2017
Author: pramsey
Date: 2017-09-27 13:54:59 -0700 (Wed, 27 Sep 2017)
New Revision: 15848
trunk/liblwgeom/cunit/cu_geos.c
trunk/liblwgeom/cunit/cu_geos_cluster.c
trunk/liblwgeom/cunit/cu_sfcgal.c
trunk/liblwgeom/cunit/cu_tree.c
trunk/liblwgeom/cunit/cu_unionfind.c
Modified: trunk/liblwgeom/cunit/cu_geos.c
--- trunk/liblwgeom/cunit/cu_geos.c 2017-09-27 06:17:25 UTC (rev 15847)
+++ trunk/liblwgeom/cunit/cu_geos.c 2017-09-27 20:54:59 UTC (rev 15848)
@@ -130,7 +130,7 @@
void geos_suite_setup(void);
- CU_pSuite suite = CU_add_suite("GEOS", NULL, NULL);
+ CU_pSuite suite = CU_add_suite("geos", NULL, NULL);
PG_ADD_TEST(suite, test_geos_noop);
PG_ADD_TEST(suite, test_geos_subdivide);
PG_ADD_TEST(suite, test_geos_linemerge);
Modified: trunk/liblwgeom/cunit/cu_geos_cluster.c
--- trunk/liblwgeom/cunit/cu_geos_cluster.c 2017-09-27 06:17:25 UTC (rev 15847)
+++ trunk/liblwgeom/cunit/cu_geos_cluster.c 2017-09-27 20:54:59 UTC (rev 15848)
@@ -368,7 +368,7 @@
void geos_cluster_suite_setup(void);
- CU_pSuite suite = CU_add_suite("Clustering", init_geos_cluster_suite, clean_geos_cluster_suite);
+ CU_pSuite suite = CU_add_suite("clustering", init_geos_cluster_suite, clean_geos_cluster_suite);
PG_ADD_TEST(suite, basic_test);
PG_ADD_TEST(suite, nonsequential_test);
PG_ADD_TEST(suite, basic_distance_test);
Modified: trunk/liblwgeom/cunit/cu_sfcgal.c
--- trunk/liblwgeom/cunit/cu_sfcgal.c 2017-09-27 06:17:25 UTC (rev 15847)
+++ trunk/liblwgeom/cunit/cu_sfcgal.c 2017-09-27 20:54:59 UTC (rev 15848)
@@ -94,6 +94,6 @@
void sfcgal_suite_setup(void);
- CU_pSuite suite = CU_add_suite("SFCGAL", NULL, NULL);
+ CU_pSuite suite = CU_add_suite("sfcgal", NULL, NULL);
PG_ADD_TEST(suite, test_sfcgal_noop);
Modified: trunk/liblwgeom/cunit/cu_tree.c
--- trunk/liblwgeom/cunit/cu_tree.c 2017-09-27 06:17:25 UTC (rev 15847)
+++ trunk/liblwgeom/cunit/cu_tree.c 2017-09-27 20:54:59 UTC (rev 15848)
@@ -384,7 +384,7 @@
void tree_suite_setup(void);
- CU_pSuite suite = CU_add_suite("Internal Spatial Trees", NULL, NULL);
+ CU_pSuite suite = CU_add_suite("spatial_trees", NULL, NULL);
PG_ADD_TEST(suite, test_tree_circ_create);
PG_ADD_TEST(suite, test_tree_circ_pip);
PG_ADD_TEST(suite, test_tree_circ_pip2);
Modified: trunk/liblwgeom/cunit/cu_unionfind.c
--- trunk/liblwgeom/cunit/cu_unionfind.c 2017-09-27 06:17:25 UTC (rev 15847)
+++ trunk/liblwgeom/cunit/cu_unionfind.c 2017-09-27 20:54:59 UTC (rev 15848)
@@ -165,7 +165,7 @@
void unionfind_suite_setup(void);
- CU_pSuite suite = CU_add_suite("Clustering Union-Find", NULL, NULL);
+ CU_pSuite suite = CU_add_suite("clustering_unionfind", NULL, NULL);
PG_ADD_TEST(suite, test_unionfind_create);
PG_ADD_TEST(suite, test_unionfind_union);
PG_ADD_TEST(suite, test_unionfind_ordered_by_cluster);
