[postgis-tickets] r15849 - Soft launch PostGIS 2.4.0
Regina Obe lr at pcorp.us
Wed Sep 27 23:50:31 PDT 2017
Author: robe
Date: 2017-09-27 23:50:30 -0700 (Wed, 27 Sep 2017)
New Revision: 15849
   branches/2.4/NEWS
   branches/2.4/Version.config
   branches/2.4/doc/release_notes.xml
   branches/2.4/extensions/upgradeable_versions.mk
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS	2017-09-27 20:54:59 UTC (rev 15848)
+++ branches/2.4/NEWS	2017-09-28 06:50:30 UTC (rev 15849)
@@ -1,46 +1,5 @@
-PostGIS 2.4.0rc3
-2017/09/27
-* Fixes and Enhancements since PostGIS 2.4.0rc2 *
-  - #3781 st_contains cannot handle curvepolygon / compoundcurve
-    consisting of only straight lines
-  - #3866 server crashing from large values in ST_AsTWKB
-  - #3818 Allow triangles unclosed in M to be WKT parsed
-  - several packaging changes regarding checking trailing blanks
-See PostGIS 2.4.0 section for details of
-new features and enhancements in this release.
-PostGIS 2.4.0rc2
-2017/09/24
-* Fixes and Enhancements since PostGIS 2.4.0rc1 *
-  - Numerous fixes to ST_AsMVT, ST_AsGeoBuf
-  - ST_AsTWKB speed and memory performance enhancments
-  - ST_RepeatedPoints speed improvements
-  - ST_ConcaveHull bug fix
-PostGIS 2.4.0rc1
-2017/09/13
-Note possible breaking changes since 2.4.0 beta1 release are:
-* Breaking Changes *
-  - B-Tree index operators < = > changed to provide better spatial locality on sorting
-    and have expected behavior on GROUP BY.
-    If you have btree index for geometry or geography, you need to REINDEX it, or review
-    if it was created by accident and needs to be replaced with GiST index.
-    If your code relies on old left-to-right box compare ordering,
-    update it to use << >> operators.
-  - ST_AsMVT aggregate now overloaded and arg order changed.
-    Check your code if you are already using this function.
-  - _ST_DumpPoints removed, was no longer needed after PostGIS 2.1.0
-    when ST_DumpPoints got reimplemented in C
-See PostGIS 2.4.0 section for details of new features and fixes in this release
 PostGIS 2.4.0
-2017/09/29
+2017/09/30
  * New Features *
   - #3822, Have postgis_full_version() also show and check version of
@@ -106,6 +65,48 @@
+PostGIS 2.4.0rc3
+2017/09/27
+* Fixes and Enhancements since PostGIS 2.4.0rc2 *
+  - #3781 st_contains cannot handle curvepolygon / compoundcurve
+    consisting of only straight lines
+  - #3866 server crashing from large values in ST_AsTWKB
+  - #3818 Allow triangles unclosed in M to be WKT parsed
+  - several packaging changes regarding checking trailing blanks
+See PostGIS 2.4.0 section for details of
+new features and enhancements in this release.
+PostGIS 2.4.0rc2
+2017/09/24
+* Fixes and Enhancements since PostGIS 2.4.0rc1 *
+  - Numerous fixes to ST_AsMVT, ST_AsGeoBuf
+  - ST_AsTWKB speed and memory performance enhancments
+  - ST_RepeatedPoints speed improvements
+  - ST_ConcaveHull bug fix
+PostGIS 2.4.0rc1
+2017/09/13
+Note possible breaking changes since 2.4.0 beta1 release are:
+* Breaking Changes *
+  - B-Tree index operators < = > changed to provide better spatial locality on sorting
+    and have expected behavior on GROUP BY.
+    If you have btree index for geometry or geography, you need to REINDEX it, or review
+    if it was created by accident and needs to be replaced with GiST index.
+    If your code relies on old left-to-right box compare ordering,
+    update it to use << >> operators.
+  - ST_AsMVT aggregate now overloaded and arg order changed.
+    Check your code if you are already using this function.
+  - _ST_DumpPoints removed, was no longer needed after PostGIS 2.1.0
+    when ST_DumpPoints got reimplemented in C
+See PostGIS 2.4.0 section for details of new features and fixes in this release
 PostGIS 2.4.0beta1
 2017/09/02
Modified: branches/2.4/Version.config
--- branches/2.4/Version.config	2017-09-27 20:54:59 UTC (rev 15848)
+++ branches/2.4/Version.config	2017-09-28 06:50:30 UTC (rev 15849)
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=2
 POSTGIS_MINOR_VERSION=4
-POSTGIS_MICRO_VERSION=0rc3
+POSTGIS_MICRO_VERSION=0
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
Modified: branches/2.4/doc/release_notes.xml
--- branches/2.4/doc/release_notes.xml	2017-09-27 20:54:59 UTC (rev 15848)
+++ branches/2.4/doc/release_notes.xml	2017-09-28 06:50:30 UTC (rev 15849)
@@ -5,7 +5,7 @@
     <sect1>
         <title>Release 2.4.0</title>
-        <para>Release date: 2017/09/29</para>
+        <para>Release date: 2017/09/30</para>
         <simplesect><title>New Features</title>
 <para>#3822, Have postgis_full_version() also show and check version of
            PostgreSQL the scripts were built against (Sandro Santilli)</para>
Modified: branches/2.4/extensions/upgradeable_versions.mk
--- branches/2.4/extensions/upgradeable_versions.mk	2017-09-27 20:54:59 UTC (rev 15848)
+++ branches/2.4/extensions/upgradeable_versions.mk	2017-09-28 06:50:30 UTC (rev 15849)
@@ -31,4 +31,5 @@
 	2.4.0beta1 \
 	2.4.0rc1 \
 	2.4.0rc2 \
+	2.4.0rc3 \
 	2.4.0dev
