[postgis-tickets] r15855 - forgot about proj - bump to 4.9
Regina Obe
lr at pcorp.us
Fri Sep 29 23:34:10 PDT 2017
Author: robe
Date: 2017-09-29 23:34:10 -0700 (Fri, 29 Sep 2017)
New Revision: 15855
trunk/README.postgis
Modified: trunk/README.postgis
--- trunk/README.postgis 2017-09-30 06:33:07 UTC (rev 15854)
+++ trunk/README.postgis 2017-09-30 06:34:10 UTC (rev 15855)
@@ -36,7 +36,7 @@
You *must* have the full PostgreSQL - including server headers - installed for
this to work.
-* PROJ4 (Required, Version 4.6.0 or higher):
+* PROJ4 (Required, Version 4.9.0 or higher):
The PROJ4 catographic projection library is required if you want to use the
ST_Transform() function to reproject features within the database.
