[postgis-tickets] [PostGIS] #3864: Sorting by geometry is slower than sorting by geohash
trac at osgeo.org
Sat Sep 30 05:20:57 PDT 2017
Reporter: komzpa | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.1
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by gsmol):
About 128GB been mercilessly eated in komzpa`s case:
via gdb I can detect that there is a lot of palloc() coming from
lwgeom_cmp, but no pfree():
#0 palloc (size=size at entry=32) at
./build/../src/backend/utils/mmgr/mcxt.c:850
#1 0x00005575da620a0a in heap_tuple_untoast_attr (attr=0x5577c344d1c0) at
./build/../src/backend/access/heap/tuptoaster.c:240
#2 0x00007f6c77386af2 in lwgeom_cmp () from
/usr/lib/postgresql/10/lib/postgis-2.4.so
#3 0x00005575da9e76b1 in comparison_shim (x=<optimized out>, y=<optimized
out>, ssup=<optimized out>)
at ./build/../src/backend/utils/sort/sortsupport.c:53
#4 0x00005575da9ec64e in ApplySortComparator (ssup=0x5575dbbb7b98,
isNull2=<optimized out>, datum2=<optimized out>, isNull1=<optimized out>,
datum1=<optimized out>) at
./build/../src/include/utils/sortsupport.h:225
#5 qsort_ssup (a=0x7f6c37b25078, n=<optimized out>, n at entry=14,
ssup=ssup at entry=0x5575dbbb7b98) at ./qsort_tuple.c:244
#6 0x00005575da9ec930 in qsort_ssup (a=0x7f6c37b24b20,
a at entry=0x7f6c37b24340, n=<optimized out>, ssup=ssup at entry=0x5575dbbb7b98)
at ./qsort_tuple.c:323
#7 0x00005575da9ec55d in qsort_ssup (a=0x7f6c37b24340, n=<optimized out>,
n at entry=778, ssup=ssup at entry=0x5575dbbb7b98) at ./qsort_tuple.c:309
#8 0x00005575da9ec930 in qsort_ssup (a=0x7f6c37b1d470, n=<optimized out>,
n at entry=40979, ssup=ssup at entry=0x5575dbbb7b98) at ./qsort_tuple.c:323
#9 0x00005575da9ec930 in qsort_ssup (a=0x7f6c37924d20, n=<optimized out>,
n at entry=140380, ssup=ssup at entry=0x5575dbbb7b98) at ./qsort_tuple.c:323
#10 0x00005575da9ec930 in qsort_ssup (a=0x7f6c3755cf20,
a at entry=0x7f6c3710f6c8, n=<optimized out>, ssup=ssup at entry=0x5575dbbb7b98)
#11 0x00005575da9ec55d in qsort_ssup (a=a at entry=0x7f6c3710f6c8,
n=<optimized out>, ssup=ssup at entry=0x5575dbbb7b98) at ./qsort_tuple.c:309
#12 0x00005575da9ec55d in qsort_ssup (a=a at entry=0x7f6c3710f6c8,
#13 0x00005575da9ec55d in qsort_ssup (a=a at entry=0x7f6c3710f6c8,
#14 0x00005575da9ec55d in qsort_ssup (a=0x7f6c3710f6c8, n=<optimized out>,
n at entry=20343532, ssup=ssup at entry=0x5575dbbb7b98) at ./qsort_tuple.c:309
#15 0x00005575da9ec930 in qsort_ssup (a=0x7f6c161fb048, n=<optimized out>,
ssup=<optimized out>) at ./qsort_tuple.c:323
#16 0x00005575da9eca89 in tuplesort_sort_memtuples
(state=state at entry=0x5575dbbb7788) at
./build/../src/backend/utils/sort/tuplesort.c:3514
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3864#comment:10>
