[postgis-tickets] [PostGIS] #3867: Can't load against PostgreSQL 11 head DatumGetJsonb renamed
trac at osgeo.org
Sat Sep 30 09:48:12 PDT 2017
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.4.1
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
I haven't backported this yet because strk said he wanted to define it as
a macro for pre-11 versions and then call the macro instead of the if-def
clauses everywhere we need them.
pramsey you okay with that? For 2.4.1 I want to just go with the IF-Def
as done above since we aren't going to be augmenting that and I hate
indirection code that is only used in one place.
We don't use ranges yet and I think JSONB is the only one at issue here.
For 2.5 main benefit I see to having it as a macro is that if we do use
JSONB in other areas of our code (which sounds likely) -- e.g. we create a
ST_AsGeoJSON that can take an anyelement and return a fully qualified
jsonb object, then having this isolated to the macro would be nice.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3867#comment:5>
