[postgis-tickets] [PostGIS] #3869: PostGIS fails to link with the gold linker due to underlinking
trac at osgeo.org
Sat Sep 30 11:05:16 PDT 2017
Reporter: mjo | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.4
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by strk):
Can you please try r15864 = 6a05f66d449fc313752016aa022076ef5d3dfa58
(refs/remotes/svn/trunk) ?
The math link was already used in liblwgeom/cunit, not sure why it wasn't
used in liblwgeom.
Maybe because PostgreSQL link line would add it in when putting everything
together in the postgis module...
If confirmed to fix the problem this should likely be backported back up
to 2.2 branch
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3869#comment:4>
