[postgis-tickets] [PostGIS] #4038: ST_Subdivide slope precision and lost boxes
trac at osgeo.org
Wed Aug 1 08:37:27 PDT 2018
Reporter: komzpa | Owner: komzpa
Type: patch | Status: closed
Priority: medium | Milestone: PostGIS 2.5.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Comment (by dbaston):
In [changeset:"16679" 16679]:
#!CommitTicketReference repository="" revision="16679"
Revert lwgeom_clip_by_rect to use GEOSClipByRect
This commit reverts lwgeom_clip_by_rect to its implementation in PostGIS
2.2 -
2.4.
It makes trivial modifications to the MVT tests to reflect the different
results
returned by GEOSClipByRect instead of GEOSIntersection. The changed
results are
topologically equivalent to the previous results, and their orientation is
unchanged.
No tests have been commented out or made version-dependent.
Closes #4134
Closes #4135
References #4038
Closes https://github.com/postgis/postgis/pull/282
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4038#comment:3>
