[postgis-tickets] [PostGIS] #4134: MVT test failure in trunk
PostGIS trac at osgeo.org
Wed Aug 1 08:37:27 PDT 2018
  Reporter:  dbaston  |      Owner:  Algunenano
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  trunk
Resolution:  fixed    |   Keywords:
Changes (by dbaston):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16679" 16679]:
 #!CommitTicketReference repository="" revision="16679"
 Revert lwgeom_clip_by_rect to use GEOSClipByRect
 This commit reverts lwgeom_clip_by_rect to its implementation in PostGIS
 2.2 -
 2.4.
 It makes trivial modifications to the MVT tests to reflect the different
 results
 returned by GEOSClipByRect instead of GEOSIntersection. The changed
 results are
 topologically equivalent to the previous results, and their orientation is
 unchanged.
 No tests have been commented out or made version-dependent.
 Closes #4134
 Closes #4135
 References #4038
 Closes https://github.com/postgis/postgis/pull/282
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4134#comment:3>
