[postgis-tickets] [PostGIS] #4104: PostGIS 2.4.4 rt_gdalwrap test fails with GDAL 2.3.0 & PROJ 5.1.0 on Debian unstable
trac at osgeo.org
Tue Aug 7 03:38:51 PDT 2018
unstable
Reporter: Bas Couwenberg | Owner: Bborie Park
Type: patch | Status: new
Priority: blocker | Milestone: PostGIS 2.5.0
Component: raster | Version: 2.4.x
Resolution: | Keywords:
Comment (by robe):
Bas,
I'm not setup to test GDAL 2.3.0 or Proj 5.1.0 at the moment. I noticed
though that the test 993309 isn't quite what we are shipping with
spatial_ref_sys. Though making it the same didn't change the answer I
get.
Can you see if that helps your regress any?
If we can't come up with a workable test for both versions of proj, I
suppose we can just take out that particular srid test.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4104#comment:8>
