[postgis-tickets] [PostGIS] #4104: PostGIS 2.4.4 rt_gdalwrap test fails with GDAL 2.3.0 & PROJ 5.1.0 on Debian unstable
PostGIS trac at osgeo.org
Tue Aug 7 04:12:33 PDT 2018
unstable
  Reporter:  Bas Couwenberg  |      Owner:  Bborie Park
      Type:  patch           |     Status:  new
  Priority:  blocker         |  Milestone:  PostGIS 2.5.0
 Component:  raster          |    Version:  2.4.x
Resolution:                  |   Keywords:
Comment (by Bas Couwenberg):
 Disabling `rt_gdalwarp.patch` and applying the changes from r16682 makes
 no difference:
  rt_gdalwarp .. failed (diff expected obtained:
 /tmp/pgis_reg/test_52_diff)
 --- rt_gdalwarp_expected        2018-07-03 20:26:25.000000000 +0000
 +++ /tmp/pgis_reg/test_52_out   2018-08-07 11:01:22.106541719 +0000
 @@ -19,8 +19,8 @@
 0.17|993309|243|243|1|50.000|50.000|0.000|0.000|950760.000|1396957.000|t|t|t
 0.18|992163|10|10|1|1000.000|-1000.000|3.000|3.000|-500030.000|600000.000|t|t|t
 0.19|993310|12|12|1|1009.894|-1009.894|3.000|3.000|950691.792|1409281.783|t|t|t
 -0.2|993309|12|12|1|1009.916|-1009.916|0.000|0.000|950762.305|1409088.896|t|t|t
 -0.20|993309|12|12|1|1009.916|-1009.916|1.000|3.000|950742.107|1409088.896|t|t|t
 +0.2|993309|12|12|1|1009.876|-1009.876|0.000|0.000|950808.447|1409091.640|t|t|t
 +0.20|993309|12|12|1|1009.876|-1009.876|1.000|3.000|950788.250|1409091.640|t|t|t
 0.21|993310|24|24|1|500.000|500.000|3.000|3.000|950657.188|1397356.783|t|t|t
 0.22|993310|26|26|1|500.000|500.000|0.000|6.000|950452.000|1396632.000|t|t|t
  0.23|984269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
 @@ -63,12 +63,12 @@
 1.9|992163|11|10|1|1000.000|-1000.000|0.000|0.000|-500001.000|600000.000|t|t|t
 2.1|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 2.10|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 -2.11|993309|121|121|1|100.000|100.000|0.000|0.000|950762.305|1396988.896|t|t|t
 +2.11|993309|121|121|1|100.000|100.000|0.000|0.000|950808.447|1396991.640|t|t|t
 2.12|993310|6|6|1|2000.000|2000.000|0.000|0.000|950732.188|1397281.783|t|t|t
 2.13|993310|8|8|1|1500.000|1500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 2.14|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 2.15|993310|16|16|1|750.000|750.000|0.000|0.000|950732.188|1397281.783|t|t|t
 -2.2|993309|12|12|1|1009.916|-1009.916|0.000|0.000|950762.305|1409088.896|t|t|t
 +2.2|993309|12|12|1|1009.876|-1009.876|0.000|0.000|950808.447|1409091.640|t|t|t
  2.3|994269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
  2.4|||||||||||||
 2.5|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4104#comment:9>
