[postgis-tickets] [PostGIS] #4144: If during writing tables that contains PostGIS geometry fields AUTOVACUUM is launched, it crashes and force PostgreSQL to restart.
trac at osgeo.org
Fri Aug 10 01:38:34 PDT 2018
Reporter: zancos | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS GDAL
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by zancos):
I have tried to get some bt captures before the failure, but they are
probably useless.
Continuing.
Program received signal SIGINT, Interrupt.
0x00007f67416570a3 in __epoll_wait_nocancel () at ../sysdeps/unix/syscall-
template.S:84
84 in ../sysdeps/unix/syscall-template.S
#0 0x00007f67416570a3 in __epoll_wait_nocancel () at ../sysdeps/unix
/syscall-template.S:84
#1 0x000055ebcdb5dcb9 in WaitEventSetWaitBlock (nevents=1,
occurred_events=0x7ffe6ff53b10, cur_timeout=-1, set=0x55ebceb20ea8) at
./build/../src/backend/storage/ipc/latch.c:1053
#2 WaitEventSetWait (set=0x55ebceb20ea8, timeout=timeout at entry=-1,
occurred_events=occurred_events at entry=0x7ffe6ff53b10,
nevents=nevents at entry=1) at
./build/../src/backend/storage/ipc/latch.c:1007
#3 0x000055ebcda91e90 in secure_read (port=0x55ebceb5e540,
ptr=0x55ebce0cffc0 <PqRecvBuffer>, len=8192) at
./build/../src/backend/libpq/be-secure.c:149
#4 0x000055ebcda9bdc3 in pq_recvbuf () at
./build/../src/backend/libpq/pqcomm.c:940
#5 0x000055ebcda9cc75 in pq_getbyte () at
./build/../src/backend/libpq/pqcomm.c:983
#6 0x000055ebcdb7fb1d in SocketBackend (inBuf=0x7ffe6ff53d10) at
./build/../src/backend/tcop/postgres.c:326
#7 ReadCommand (inBuf=0x7ffe6ff53d10) at
./build/../src/backend/tcop/postgres.c:499
#8 PostgresMain (argc=<optimized out>, argv=argv at entry=0x55ebceb690e0,
dbname=<optimized out>, username=<optimized out>) at
./build/../src/backend/tcop/postgres.c:4017
#9 0x000055ebcd8f4bd8 in BackendRun (port=0x55ebceb5e540) at
./build/../src/backend/postmaster/postmaster.c:4342
#10 BackendStartup (port=0x55ebceb5e540) at
./build/../src/backend/postmaster/postmaster.c:4016
#11 ServerLoop () at ./build/../src/backend/postmaster/postmaster.c:1721
#12 0x000055ebcdb1d492 in PostmasterMain (argc=5, argv=0x55ebceb1ee10) at
./build/../src/backend/postmaster/postmaster.c:1329
#13 0x000055ebcd8f5f44 in main (argc=5, argv=0x55ebceb1ee10) at
./build/../src/backend/main/main.c:228
Continuing.
template.S:84
Breakpoint 1 at 0x55ebcdc87b40: file
./build/../src/backend/utils/error/elog.c, line 414.
Continuing.
template.S:84
Continuing.
Program received signal SIGQUIT, Quit.
template.S:84
Backtrace stopped: Cannot access memory at address 0x7ffe6ff53a38
Detaching from program: /usr/lib/postgresql/9.6/bin/postgres, process 5678
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4144#comment:4>
