[postgis-tickets] [PostGIS] #4144: If during writing tables that contains PostGIS geometry fields AUTOVACUUM is launched, it crashes and force PostgreSQL to restart.
trac at osgeo.org
Sat Aug 11 00:23:07 PDT 2018
Reporter: zancos | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.4.5
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Changes (by robe):
* priority: medium => blocker
* milestone: PostGIS GDAL => PostGIS 2.4.5
Comment:
Why is this marked as PostGIS GDAL? raster isn't even at play here so
GDAL in theory should not be involved unless the .so files are fighting
with each other. Also at a glance at your bt I don't see any postgis
components showing up as a culprit.
I wasn't able to make your example crash on
PostgreSQL 10.3, compiled by Visual C++ build 1800, 64-bit POSTGIS="2.4.4
r16526" PGSQL="100" GEOS="3.6.2-CAPI-1.10.2 4d2925d" PROJ="Rel. 4.9.3, 15
August 2016" GDAL="GDAL 2.2.4, released 2018/03/19" LIBXML="2.7.8"
LIBJSON="0.12" LIBPROTOBUF="1.2.1" RASTER
or
I revised your example a bit - here is what I ran
CREATE SCHEMA IF NOT EXISTS bug_schema;
CREATE EXTENSION postgis SCHEMA bug_schema;
CREATE TABLE "bug_schema"."bug_table" (
"#tbl" bigserial NOT NULL ,
"guid" uuid NOT NULL DEFAULT NULL,
"text" varchar(255) COLLATE "pg_catalog"."default" NOT NULL DEFAULT
NULL,
"metadata" json NOT NULL DEFAULT NULL,
"bounding_box" "bug_schema"."geometry" NOT NULL DEFAULT NULL,
"flag" bool NOT NULL DEFAULT NULL,
"pose" float8[] NOT NULL DEFAULT NULL
INSERT INTO bug_schema.bug_table(guid, "text", "metadata",
bounding_box, flag, pose )
SELECT '28ef049e-9d36-11e8-80b0-00000a3a2e20'::uuid,
'hello', '{"name": "hello", "age": 10}'::json,
bug_schema.ST_MakeEnvelope(1,2,3,i, 4326),
true, '{1908098080934,190808.2908}'::float8[]
FROM generate_series(1,10) AS i;
vacuum analyze verbose;
Can you provide an example of an insert that triggers the error. Might
have to do with play of NULLS and so forth.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4144#comment:5>
