[postgis-tickets] [PostGIS] #4144: When ANALYZE a table that contains certains values on a geometry field, PostgreSQL crash (was: If during writing tables that contains PostGIS geometry fields AUTOVACUUM is launched, it crashes and force PostgreSQL to restart.)
PostGIS trac at osgeo.org
Tue Aug 21 05:14:30 PDT 2018
PostgreSQL crash
  Reporter:  zancos   |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.4.5
 Component:  postgis  |    Version:  2.4.x
Resolution:           |   Keywords:
Comment (by zancos):
 Issue edited.
 Trigger: when in a geometry field is pushed a GEOMETRYCOLLECTION with more
 than two points, and one of these points has, at least, one value
 containing a number smaller than -3.385894e+38 (which is not the limit)
 and then if ANALYSE the table, PostgreSQL crash and force the database
 engine to restart.
 Due to ANALYSE is executed before vacuum tables when autovacuum is called,
 also PostgreSQL crash when inserting values into database and at least
 there is one of this fields filled in with this "problematic" value.
 This code reproduce the error:
 -- Prepare schema and populate postgis extension
 CREATE SCHEMA bug_schema;
 CREATE EXTENSION postgis SCHEMA bug_schema;
 -- Table structure for scan
 DROP TABLE IF EXISTS bug_schema.bug_table;
 CREATE TABLE bug_schema.bug_table (
   "geometryField" bug_schema."geometry" NOT NULL DEFAULT NULL
 PREPARE stmt AS INSERT INTO bug_schema.bug_table ("geometryField") VALUES
 ($1);
 EXECUTE stmt ('GEOMETRYCOLLECTION(POINT(-3.385894e+38 0 0),POINT(0 0
 0))');
 DEALLOCATE stmt;
 ANALYZE;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4144#comment:6>
