[postgis-tickets] [PostGIS] #4282: ST_LineToCurve hangs indefintely
trac at osgeo.org
Thu Dec 27 07:31:29 PST 2018
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
I thought I had tested this in 2.5 and garden tests ran to completion.
On trunk branch however, for PostgreSQL 12, this test hangs indefinitely.
I let it sit there and work up 5 hrs later and it was still stuck.
SELECT ST_Area(foo1.the_geom) As result FROM ((SELECT
ST_LineToCurve(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j)) As the_geom
FROM generate_series(-10,50,10) As i CROSS JOIN generate_series(40,70, 20)
As j ORDER BY i, j, i*j) ) As foo1 LIMIT 10;
I'm guessing it's not the ST_Area and most likely the ST_LineToCurve at
fault here.
In addition to hanging indefinitely, it's not cancellable
I'll isolate it down to that and if it's a pg12 issue or a PostGIS 3.0
issue.
This I ran against PostgreSQL 12 head as of 12/27/2018
version
PostgreSQL 12devel on x86_64-w64-mingw32, compiled by gcc.exe (x86_64
-posix-seh-rev0, Built by MinGW-W64 project) 8.1.0, 64-bit
(1 row)
postgis_full_version
POSTGIS="3.0.0dev r17118" [EXTENSION] PGSQL="120" GEOS="3.7.0-CAPI-1.11.0
673b9939" SFCGAL="1.3.2" PROJ="Rel. 5.2.0, September 15th, 2018"
LIBXML="2.7.8" LIBJSON="0.12" LIBPROTOBUF="1.2.1"
(1 row)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4282>
