[postgis-tickets] [PostGIS] #4282: ST_LineToCurve hangs indefintely
trac at osgeo.org
Thu Dec 27 07:32:10 PST 2018
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Description changed by robe:
Old description:
> I thought I had tested this in 2.5 and garden tests ran to completion.
> On trunk branch however, for PostgreSQL 12, this test hangs indefinitely.
> I let it sit there and work up 5 hrs later and it was still stuck.
> SELECT ST_Area(foo1.the_geom) As result FROM ((SELECT
> ST_LineToCurve(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j)) As the_geom
> FROM generate_series(-10,50,10) As i CROSS JOIN generate_series(40,70,
> 20) As j ORDER BY i, j, i*j) ) As foo1 LIMIT 10;
> I'm guessing it's not the ST_Area and most likely the ST_LineToCurve at
> fault here.
> In addition to hanging indefinitely, it's not cancellable
> I'll isolate it down to that and if it's a pg12 issue or a PostGIS 3.0
> issue.
> This I ran against PostgreSQL 12 head as of 12/27/2018
> version
> PostgreSQL 12devel on x86_64-w64-mingw32, compiled by gcc.exe (x86_64
> -posix-seh-rev0, Built by MinGW-W64 project) 8.1.0, 64-bit
> (1 row)
> postgis_full_version
> POSTGIS="3.0.0dev r17118" [EXTENSION] PGSQL="120"
> GEOS="3.7.0-CAPI-1.11.0 673b9939" SFCGAL="1.3.2" PROJ="Rel. 5.2.0,
> September 15th, 2018" LIBXML="2.7.8" LIBJSON="0.12" LIBPROTOBUF="1.2.1"
> (1 row)
New description:
I let it sit there and woke up 5 hrs later and it was still stuck.
FROM generate_series(-10,50,10) As i CROSS JOIN generate_series(40,70, 20)
fault here.
issue.
version
(1 row)
POSTGIS="3.0.0dev r17118" [EXTENSION] PGSQL="120" GEOS="3.7.0-CAPI-1.11.0
673b9939" SFCGAL="1.3.2" PROJ="Rel. 5.2.0, September 15th, 2018"
(1 row)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4282#comment:1>
